Hi
I am working on a new version of a hobby soldering station. The first version I made (SolderingRT1,
https://gitlab.com/pittinihub/solderingrt1) works very well with Weller RT tips and tweezers.
However, I wanted to add functionality and make it compatible with other tips (like JBC and others).
The Weller tweezers are expensive and recently Atten made some similar ones (example: ST-1509 N9100). These are very similar to Weller ones.
Example:
https://www.aliexpress.us/item/3256803404139133.html?gatewayAdapt=glo2usa4itemAdaptThe Atten tweezers ST-1509- N9100 have a very similar structure as Weller. They work with 12V (3R resistive element) and have a thermocouple.
The connections are the following: HeaterLeft, TCleft, GND, TCright, HeaterRight. The thermocouple type is different than the Weller but, I can fix that with a proper calibration and mapping.
Now the main challenge:
- In the Weller tweezers the TC are reference to GND and they generate a positive voltage compared to GND like few mV that then get amplified etc..
- In the Atten tweezers the TC seem reference to GND but "inverted polarity" so actually they generate a negative voltage on the TCpin
As the voltage on the Atten tweezers is negative I cannot the normal amp stage I used before. A solution would be using a differential amplifier with dual supply and adding an offset to it. However, this adds expensive opamps (I am trying to make it KISS style) and a bit of complexity.
So I wanted to try to get inspiration from Atten designers
Does anyone has an Atten station (ST-1509 or GT-6200) and can post some pictures of the PCBs /teardown?
Or does someone has a schematics for those stations?
Thanks everyone
