Author Topic: What width size solder wick do you use the most?  (Read 1384 times)
Offline artvandalaiTopic starter
« on: October 15, 2024, 12:45:59 am »
What brand and width size of solder wick do you find using the most?
Offline themadhippy
Re: What width size solder wick do you use the most?
« Reply #1 on: October 15, 2024, 01:08:21 am »
Chemtronics chem-wik  yellow/1.5mm .  https://www.chemtronics.com/chem-wik-rosin    Ive tried a few other brands  but nothing seems to work as well for me
The following users thanked this post: artvandalai
Offline tooki
« Reply #2 on: October 15, 2024, 06:53:26 am »
MG Chemicals, Chemtronics, Edsyn are all good.
As for size: I have them all and use them all. The wick size needs to match the joint being cleared. Too wide and you contact adjacent things you don’t want to wick off. Too thin and you saturate the wick way too soon, so you have to use up a lot more wick, and have to heat the joint much longer than necessary. (Don’t forget that the price of solder wick is largely independent of width (with many, you pay about the same for the same length regardless of width), so wide wick sucks up a lot more solder per dollar.) Onoy the very widest wick (which many companies don’t make) is disproportionately expensive.
Offline David Hess
  • DavidH
« Reply #3 on: October 15, 2024, 07:19:17 am »
I am currently going through a spool of Techspray Pro Wick size #4, which is 0.098" 2.5mm.
Offline wasyoungonce
« Reply #4 on: October 15, 2024, 10:15:42 pm »
I use #3 ….says chemtronics but probably fake.   No problem.  Either dip a length of it in rosin flux or wipe gel Rosin flux along it.   It sucks solder like pulling a sailor off ya sister!
Best trick ever.
I'd forget my Head if it wasn't screwed on!
