Author Topic: Bead Thermocouple Velcro Strap  (Read 445 times)
Offline brimsTopic starter
« on: December 06, 2024, 03:23:24 pm »
I regularly use beaded thermocouples at work, the bare bead is fine except that I run through a lot of electrical tape attaching them for the few minutes I need to take readings. The Fluke clamp is nice, but expensive and won't fit most of the pipes I need to take readings of. I like the velcro strap version, but I'm not spending $140+ for a pair of them when I could buy 100 bead thermocouples and 10 miles of electrical tape for that price.
I have been searching for the brass ferrule, for lack of a better description, that these velcro thermocouples use to attach the beaded thermocouple to the velcro strap but can't seem to find anything. My question is, does anyone have any idea what this piece is called, where to source them, or any other information? Thanks in advance.
Online thm_w
  • Non-expert
Re: Bead Thermocouple Velcro Strap
« Reply #1 on: December 06, 2024, 10:33:51 pm »
It would help if you linked the fluke product in question or added a photo: https://www.myflukestore.ca/p4132/fluke_80pk-11_type-k_velcro_thermocouple_temperature_probe.php youtube.com/watch?v=5neEm_Tzp00
So it looks like its for wrapping around a pipe.
I don't think the brass part is necessarily needed? You could use a thermal pad behind the sensor. But maybe that part would give it better contact. Anyway, you can either find different thermocouple type with a flat bottom, or use the crimp you are talking about, and secure it to the velcro with thread or glue.
https://www.digikey.ca/en/products/detail/te-connectivity-amp-connectors/41559/288437
https://www.aliexpress.us/item/3256803237040242.html
https://www.aliexpress.us/item/3256804356401949.html
