Author Topic: LCD outdoor touch display (esp32) 5-10 inch - where to find?  (Read 1014 times)
Offline CvijoTopic starter
  • Country: hr
Hi everyone,
I am not sure if I am putting this question into the correct section of the forum but does anyone know any LCD display that is for outside use (marine grade). Need it to be installed on the boat, so wet hands, rain, etc.
I would like to control it with ESP32 (nothing special about the graphics, only some buttons to press :).
So far i am using CrowPanel display
5in - https://www.elecrow.com/esp32-display-5-inch-hmi-display-rgb-tft-lcd-touch-screen-support-lvgl.html
7in - https://www.elecrow.com/esp32-display-7-inch-hmi-display-rgb-tft-lcd-touch-screen-support-lvgl.html
they have integrated esp32 but doesn't have to be integrated, and they are not for outdoor use
Thank you
Offline thm_w
  • Non-expert
Re: LCD outdoor touch display (esp32) 5-10 inch - where to find?
« Reply #1 on: March 18, 2025, 10:07:58 pm »
Budget? Its going to be hard to find unless you want to spend a reasonable amount, afaik.
You can google IP67 touch LCD embedded (or IP66, whatever), and you'll find some results.
You could take the existing crowpanel display, and seal it inside a waterproof enclosure. So the front glass will still be accessible.
I've never seen touch panels work that well when it is raining directly on them though. So thats something for you to test.
