if your in Europe you wont be getting lead based solder now.TME has removed it from the site, RS has this notice.
I've heard of SN100C but don't know a lot about it. How well it flows, temperature etc.? Does it eat soldering iron tips?
the u.s. wont ban lead, it will piss off the gun collectors too much.
are you sure about that?they banned it in mainland europe, and they banned lead for fishing weights too.
monkey, why do you need lead bullets?
the military fire copper bullets with a steel core, why do you think you need lead?
monkey, why do you need lead bullets?To make sure the perp dies of lead poisoning as well after shooting him.
Quote from: Telstar on February 28, 2013, 08:00:46 pmthe "no clean" type doesnt use Rosin, but something else.FWIW, some no-clean formulations use rosin as it's base resin. It's just filtered a lot more than it is with a traditional rosin formulation, usually followed by some different chemistry processing going on.Quote from: 691175002 on March 23, 2015, 04:50:58 pmI had some 62/36/2(Ag) which was great. Ran out and bought some 63/37 Kester. Wouldn't use 60/40 again.Snagged a couple of 1.5oz. spools from the one RadioShack that was closing here in town, as it's not something I frequently use. Regarding Rat Shack solder, my existing spool works very well, but it's out of the early '90's. Figure worst case, I can add flux with the current stuff if it doesn't wet.
soldering tips are eaten by flux, not solder.leaving agressive flux on the tip will eat through them pretty fast.i use very mild flux cored solder (HS10 / Kristall505/511) so my tips are not effected.
I had a spool of the RadioShack 62/36/2 Silver-bearing solder from the '90s too that finally ran out. I just picked up another couple 1.5oz spools off RadioShack's website a month ago. I just haven't found anything that solders as easily as this does or makes shiny strong joints. So far the new stuff seems just as good. Cleanup is easy with IPA. I tried a roll of Gootwick and it was terrible. I think they forgot to put the flux in it. I have a few rolls in different sizes of MG Chemicals Superwick and it works really well without adding any additional flux.
Quote from: stj on February 26, 2019, 07:10:02 pmsoldering tips are eaten by flux, not solder.leaving agressive flux on the tip will eat through them pretty fast.i use very mild flux cored solder (HS10 / Kristall505/511) so my tips are not effected.According to the Pace marketing rep, lead free alloys are much more corrosive. Bad for tips. I'll never use lead free.
How does lead-free affect soldering? There is a higher tin content, higher melting points, tighter process window, decreased wetting, longer dwell times, duller solder joints – all these elements can affect tip life. It's been estimated that Tip life can be decreased by up to 2/3 when using lead-free! Increased Tin Content + Higher Temperatures = Aggressive Corrosion: Lead-free solder is much more corrosive to iron-plating than standard 63/37 tin-lead alloy, especially at elevated temperatures. Higher Sn (tin) content, higher idling temperatures, greater rate of oxidation, and rapid flux degeneration all contribute to lower tip life. The most important thing to remember is the higher the tip temperature, the higher the likelihood of increased plating erosion due to iron leaching.
350C tip temperature is not uncommon, and it solders lead free well. If you play with some very temperature sensitive stuff like GaAs microwave chips, then there are other lead free solder alloys, such as Sn42Bi57Ag1.I haven't used SnPb for a long time on my own projects, and I don't feel soldering to be hard at all.
Quote from: labjr on February 26, 2019, 09:40:37 pmQuote from: stj on February 26, 2019, 07:10:02 pmsoldering tips are eaten by flux, not solder.leaving agressive flux on the tip will eat through them pretty fast.i use very mild flux cored solder (HS10 / Kristall505/511) so my tips are not effected.According to the Pace marketing rep, lead free alloys are much more corrosive. Bad for tips. I'll never use lead free.lolpace-rep is a liar or fool.alloys arent corrosive, other than copper leaching - and that has been pretty much solved now.besides, very few people have exposed copper soldering tips - they are iron-plated.it's the flux that does damage - that's it's job.
