Products => Other Equipment & Products => Topic started by: Jschool on May 20, 2011, 01:12:14 pm
Anyone have experience with this multimeter? Yeah I know I can get a second hand Fluke 87-3 for a bit less, but I can get this one new and if it has the same shortcoming as the $100 model (not indestructable like the Fluke) that's okay -- I'm not intending to use this for field tech work.
I don't own this meter but know B&K's reputation is good, its spec sheet is typically accurate.
391A is a manual ranging DMM, pricey for the list price they want with these specs.
http://www.bkprecision.com/products/model/391A/test-bench-true-rms-dmm-with-protective-rubberized-case.html (http://www.bkprecision.com/products/model/391A/test-bench-true-rms-dmm-with-protective-rubberized-case.html)
