Author Topic: Need Converter for 13V5 to 13V5 at 25W, isolated  (Read 678 times)
Offline FaringdonTopic starter
« on: February 03, 2022, 01:05:46 pm »
Does anyone sell an offtheshelf isolated converter to get from 13V5 input to 13V5 output at 25W?
Or if not, then what about as above, but with 15V input, or 24V input?
'Perfection' is the enemy of 'perfectly satisfactory'
Online Ian.M
Re: Need Converter for 13V5 to 13V5 at 25W, isolated
« Reply #1 on: February 03, 2022, 01:34:52 pm »
TDK-Lambda have some models with 10% trim range.  Trim a 15V output one down 10%.
The following users thanked this post: Faringdon
Offline HumbleDeer
« Reply #2 on: February 05, 2022, 03:41:28 am »
What about using a standard isolator, and perhaps a convertor afterwards? It's inefficient but might be easiest depending on your case.
