If anyone wants to know, PIN 1 to PIN 6 or blue to violet serve two purposes.
When an appropriate wand/handle is connected, a 44-45k ohm resistor will be across these two, signaling that the wand is 80 Watts.
Upon pressing the switch, the circuit is completed, initiating the activation of the air/vacuum pump.
