Hey,
I've just watched a video of Dave removing an IC with a very high pin count using chip quik solder very easy. For anyone that is not aware chip quik is an alloy that can be added to existing solder, it has a very low melting point so when heated it says melted for much longer than regular solder. This is ideal for removing processors and things like display connectors.
I had a look online for this product and it cost way more than I'd like to pay, I'd probably use this quite a lot with the work I do.
Has anyone found a cheap alternative to this product?
