Author Topic: Comparing 4 Different Digital Microscopes  (Read 11952 times)
Offline ProtoG42Topic starter
« on: January 04, 2018, 07:57:45 pm »
https://youtu.be/dgQWt7Z3eko
In the video I compare the following 4 microscopes with built in displays:
Generic 4.3" Microscope that records 720P and takes 3MP photos
Generic 2.5" Microscope that records 720P and takes 3MP photos
Andonstar ADSM201 Microscope that records 1080P and takes 12MP photos
Andonstar ADSM302 Microscope that records 720P and takes 12MP photos
I have seen the ADSM201 discussed on this forum and by Dave.  The ADSM302 is the recently released newer model of the ADSM201.  They seemed to improve on some of the gripes people had with the older model.
The camera sensor is larger and the working distance has been increased by quite a bit because of the elongated tube for the lens to move.
The screen is larger and higher quality with the ability to adjust the angle.
The base is much larger and heavy than the previous model.  It is also black compared to the reflective silver of the older model.  The silver made it hard to look at single components without glare.
Here's a photo of solder paste on a toothpick:
Here's a photo of a WS2812 LED die:
« Last Edit: January 04, 2018, 08:06:29 pm by ProtoG42 »
The following users thanked this post: ChunkyPastaSauce
Re: Comparing 4 Different Digital Microscopes
« Reply #1 on: January 04, 2018, 10:43:58 pm »
Here are more photos of a 2cm wide board taken with the 4 units:
Andonstar ADSM302 taken @ 20.5cm
Andonstar ADSM201 taken @ 12cm
2.5" "Koolertron" Microscope taken @ 11cm with no light
2.5" "Koolertron" Microscope taken @ 11cm with light at lowest setting
4.3" "Koolertron" Microscope taken @ 21cm
The following users thanked this post: msliva, ChunkyPastaSauce, madcat
« Reply #2 on: January 06, 2018, 01:53:12 am »
Here's more footage
Offline kalel
« Reply #3 on: January 06, 2018, 01:59:26 am »
Nice review, and some great (very sharp and focused) images. I cannot get comparable quality with the cheapo $16 microscope, but... that's to be expected after all. :)
The following users thanked this post: ProtoG42
Offline BravoV
  • +++ ATH1
« Reply #4 on: January 06, 2018, 02:17:38 am »
Thanks for the comparison, really nice.  :-+
« Reply #5 on: January 06, 2018, 04:51:35 am »
Thanks guys!
Offline madcat
  • Country: id
« Reply #6 on: February 28, 2018, 09:51:17 am »
thank you for the comparison. just ordered the one with 4.3" display. i hope it's good enough for hobbyist with tight budget like me.  :)
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
« Reply #7 on: February 28, 2018, 01:58:34 pm »
Here some difference in Ando a star microscop :palm: ADSM201/301/302
To the poster of the video, please look up the words: "lapel (lavalier) microphone". It will greatly improve your audio. Nothing like recording audio in a large sewer pipe. AKA: Are you on speakerphone? "Oh no.." Says the person on the other end in the marble room.
As far as the 302, show me movement whilst it is in the zoom mode. I'd like to see if it is truly non-delayed as in the x1 mode. Also, does the software identify in Chinese in the hardware manager as shown, or instead in English?
« Last Edit: February 28, 2018, 02:12:19 pm by Quarlo Klobrigney »
Voltage does not flow, nor does voltage go.
Offline uktron
« Reply #8 on: October 02, 2019, 06:30:01 am »
If somebody have andonstar 301/302 (or may be 201), can you please look inside and write hier wich image sensor is used in this microscope.
