More like outright ignorant. They've made a point of maintaining battery compatibility for decades. It's one of their selling points.
Right. Well I did start off by asking for opinions and advice, so is the rest of the community happy with that endorsement of Ryobi?
MarkMLl
It depends. If you use your tools professionally or heavy hobbiest use, then I would recommend one of the name brands. I own several tools and batteries from the old Sears Craftsman C3 19.2V line which are re-badged Ryobi One Battery line tools (BUT their batteries and tools are not cross compatible, the stub that goes into the tool and the electrical connections are different, but they are essentially the same tools and batteries as the Ryobi). They will do the job, the drills are powerful enough for most of my needs, I mainly use and literally abuse the recip saw for pruning duties and it has held up quite well, happy with the performance of the trimsaw I used it pretty heavily when I built several projects where I needed to cut sheets of plywood and building my workshop, but I was disappointed with the 7-1/4" circular saw, just a bit underpowered and will drain a battery quickly. So based on my experience, I would say that Ryobi's power tools are good for DIY'ers up to heavy DIY'ers.
Of course, it should be said, that just because Ryobi has kept their battery design the same for the last 20 or so years, does not mean that they will not change it in the next few years. Of course, I would anticipate they would make an adapter for older tools to use whatever new batteries they come out with, but that's not a guarantee, either. My defense of Ryobi was only to point out that the author was off base when stating that they could not use new batteries with old tools, which was wrong, unless the author had not bought Ryobi tools since they introduced the One Battery lineup, which must have been a very long time ago.
Edit to add: I have two of the C3 drills, one normal 1/2" and one 1/2" hammerdrill. If you are looking for tools to use for home maintenance duties, I highly recommend getting a hammerdrill in lieu of a normal drill, I never thought a cordless hammerdrill would be useful, it has been used much more than I thought and works much better than I thought. If this will strictly be used for screwing together woodworking type projects or drilling electronics enclosures, etc. types of projects, then a normal drill will suffice.
