Author Topic: DIY weller WMRP/WMRT soldering station project (open source)  (Read 3589 times)
Offline nexusTopic starter
Hi all,
Thought I'd share a writeup I did on an open source project I built. I wanted to use a nice set of Weller hot tweezers for small SMT rework but did not want the compatible boat anchor station. I found this open-source alternative that was a fun project by itself and could be built on the cheap too! The project repository is linked in the article.
https://neonkev.com/2020/07/16/diy-weller-wmrp-wmrt-soldering-station-open-source/
Cheers
The following users thanked this post: thm_w, ch_scr
Offline thm_w
  • Non-expert
Re: DIY weller WMRP/WMRT soldering station project (open source)
« Reply #1 on: July 16, 2020, 08:43:25 pm »
Nice clean build.
Is it using the two heaters in series and one thermocouple?
Relevant link: https://www.eevblog.com/forum/reviews/whats-inside-weller-wmrt-tweezers/25/
The following users thanked this post: nexus
« Reply #2 on: July 17, 2020, 02:34:35 am »
Thanks. I'm a little OCD, so the final assembly took wayy to long.
This design uses a dual mosfet and dual auto zero op amp; each heater is being monitored and cycled independently. Attached a photo of that part, the entire circuit diagram is online here: http://kair.us/projects/weller/weller_driver_v11_circuit_diagram.pdf
