Well,after some thinkering, I decided to dismantle original heater,carefully cutting the ceramics.It is wire wound classic heater with temp probe.Heater wire was broken inside,I conected it again with crimping sleeve,and it works.It is good to go in service.
And in the future,if new replacement heater wouldnt be available,by looking at the construction of the dismantled heater,it will be possible make completly new one with some resistance wire and fire clay(only that part is tricky).
Zero money spend,sometimes, it is worth risking if you have nothing to lose..
