so my wife made me fall out of my chair when she ok'd me buying a 3d scope for my hobby.
now for reference for inspection i currently use a cheap radioshack handheld 60x-100x thing it works but is difficult to say the least.
link I am soldering everything by eye right now and 0402s are doable but arent the most comfortable, or easiest to work with
anyway I am looking at 3 options right now.
first option is a new
amscope Simul-Focal trinocular boom mount with a LED ring light (no camera from them I am gonna use my Nikon D3200 for that,
$80 mount to mount the cam to the scope
(around $800 for the setup)
pros - wide range of magnification, camera
cons - eyepieces
second option is a new Mantis Compact scope $1025 with boom arm mount (may choose the stand mount, not sure)
pros - no eye pieces
cons - most expensive, only up to 10x magnification, no camera option
third option is a used Mantis M001 which is the original style mantis that alot of places are selling off now. I can get them for around $800-$900 on ebay depending from what I saw
pros - up to 20x mag
cons - used , no camera
I am leaning towards the amscope because I am only gonna be using it a few times a week for at most an hour or two at a time so I don't know how much of a premium the ocularless mantis design would be. also with the amscope it is possible to do a 3d display for it by getting 2 fast cameras (one for each eyepiece) and feeding that into a modern 3d monitor, I would have to wear the glasses, but it would be a nice large depth enabled view of the work. (probably 500 for that project though so it would be in the future)
between this and a new temp controlled iron (with the capability of heated tweezers hopefully) I will be much better setup
this is my little project that I'm proud of I am working with right now, it is a micro-launchpad. like the full size TI lauchpad, but for the tssop package of the MSP430. the uLP board is 14mm x 19mm with a micro USB socket for charging, the voltage regulating stuff, and also lipo battery charging support to power it.
the first "booster pack" i made for that size is for a little OLED screen (UG-2864HSWEG01) the booster pack has two interface buttons, and mounts the screen itself. the booster board, and uLP hide completely behind the screen as you can see in the
