Author Topic: Thinking about a Hakko FX-951 and FM-2032  (Read 4534 times)
Offline alank2Topic starter
« on: March 26, 2018, 06:10:19 pm »
I've been using a weller WES51 and can do down to 0.8 mm pins with it without too much trouble.  Sometimes though I need to work with 0.66/0.6/0.5mm pitch as well.  Would a FX-951/FM-2032 be a good combination for this?  Also, some of the tips for the standard iron that comes with the FX-951 look pretty sharp/small, would they do almost as well as the FM-2032?  Is there something else that I should consider/think about?
Re: Thinking about a Hakko FX-951 and FM-2032
« Reply #1 on: March 27, 2018, 03:42:32 pm »
Nobody wants to talk about soldering irons????!?!?!?!?!? :)
Offline sn4k3
  • Country: pt
« Reply #2 on: March 27, 2018, 04:59:11 pm »
You can try smaller tips for your station, eg: https://www.tequipment.net/WellerETU.html (0.38mm chissel), https://www.tequipment.net/WellerETV.html (0.61mm chissel)
If you want to go Hakko they have tiny tips that work good, they down to 0.15mm
also you have ERSA option down to 0.3mm tip
« Last Edit: March 27, 2018, 05:09:42 pm by sn4k3 »
Offline thm_w
  • Non-expert
« Reply #3 on: March 27, 2018, 09:48:34 pm »
If this is their only selection it seems quite limited: https://www.hakko.com/english/tip_selection/series_t30_standard_large.html
You'd be fine with normal T12 tips.
The advantage of the fm2032 to me would be the much nicer looking handle/ergonomics.
