After many years of dependably adequate service, I finally had enough of patching the rubber bulb on my 45w EGC Desoldering Iron - you know the type, looks like a standard pencil iron, but with an extra tube coming off the hollow-point tip that leads to a (usually) red rubber bulb. Squeeze bulb, place tip over pin, release the bulb and it sucks up most of the solder.
Bought a Hakko FR-301 and never looked back. It's their "entry level" desoldering gun but it has served me professionally for years now with nary a complaint - any issue I've experienced (basic amateur problems like poor heat transfer or clogged tips) have all been due to my own ignorance. Take the time to learn how to use and service it properly (or any other desoldering gun for that matter) and you'll be amazed how much value it will bring to your quality of work and to your own personal happiness at a job done once and done well.
Service parts like tips and filters and seals and heating elements (try not to drop yours forty feet down to the floor inside a pipe organ... the falling isn't the issue, but it won't like the sudden stop when the tip hits the ground) are kinda expensive, but they're only "Hakko expensive," not like "Metcal expensive." I know the prevailing opinion on these forums is knock-off parts are cheaper and work just as well, but that's only half true, specifically the "cheaper" part of the equation. Just suck it up and buy the parts from Hakko. It's 2024, and like every decent company they have an online store that makes finding parts a breeze, no guesswork or forum question threads necessary.
Get yourself a Hakko FR-301. As Abe Froeman, the Sausage King of Chicago, once said: "It is so choice. If you have the means, I highly recommend it."
