Author Topic: Vacuum pump - ideas?  (Read 2067 times)
Offline ralphrmartin
    • Me
« on: October 26, 2016, 06:35:37 pm »
I've inherited a small vacuum pump - a Rietschle Picolino VTE3 to be precise. Anyone have any good ideas for something to do with it?
Re: Vacuum pump - ideas?
« Reply #1 on: October 26, 2016, 07:29:37 pm »
Good vacuum source for a desoldering station instead of the usual venturi system, though you will need to install a better inline filter than it comes with to keep the particulate material in the suction from condensing on the vanes and housing. Regular compressed air filter housing ( with the drain port either sealed or blocked off) and a 0.3micron filter element, will do for that.
Offline ebclr
« Reply #2 on: October 26, 2016, 07:43:15 pm »
Air conditioner gas change
Pick and place devices
Making tubes and Nixes
It's a very useful  device,
 :D
    • Me
« Reply #3 on: October 27, 2016, 05:47:47 pm »
Thanks guys. Keep them coming - soon one will ring my bell...
Offline thefamilyman
« Reply #4 on: October 28, 2016, 03:28:10 am »
Swedish made penis enlarger?
Offline rs20
« Reply #5 on: October 28, 2016, 03:30:49 am »
-- Pick and place devices
-- Making tubes and Nixes
The requirements for these two applications are so dramatically different; it just highlights that "vacuum pump" on its own is a very vague concept.
Offline Akra
« Reply #6 on: October 28, 2016, 06:21:50 am »
It is like saying you have a vehicle, it could be a truck, a prius or a Formula One car...
But At the beginning he pointed out the exact type: It is a graphite rotary pump, good for medium vacuum applications
e.g. pick and place, degassing epoxy, faster/gentle drying, letting marshmallows grow etc.
but not enough for tubes or other higher vacuum stuff.
Offline ChristopherN
    • app22 UG (haftungsbeschr√§nkt)
« Reply #7 on: October 29, 2016, 05:34:23 pm »
I'm using my vacuum pump to degas silicone castings. You can make nice looking (and flexible, if you want) housings. I'm using that method to cast sensor housings that see a lot of mechanical stress like drops and temperature swings.
