hello :
Thank u for the comment's , now I need to know ,where is the mains problem with the panel meter , and if someone can give me the solution ,
I think that if I'll buy 0.1% ( or better ) 1/2W divider resistors, and I'll replase the present one's , boom ... the problem is solved ?? or temp stability ( Ppm's ) is the problem here ?
well I don't know , what I am trying to ask is : can I Hack this panel meter to be more relable ( tolerance/temp ) or even more accurate ?
What ever I'll do , I know that this meter has 20,000 max count so the max voltage I am going to messure will be 20V , there for I need to build " auto range meter "( only switch between the different 3 resistors : 10K , 100K , 1M ) just to make my power supply more fancy
, when I'll go lower then 2V I'll be able to see the reading's with 100uV resolution o_o !! and when the voltage go grater then 2V my resolution will be 1mV !! and when the voltage will be grater then 20V my resolution will be 10mV , yea I know , very very fancy , but I work very hard for this power supply
so I can let myself enjoy from perfect power supply ( well at least right now
) . so for the "auto range " circuit I think to use some zeners , resistors,op-amp ( maby copper one's ) and MOSFET's ( I can get one's as low as 1mohm RDS on . BTW to make this power supply even more professional , I think to use kind of " auto rang " circuit to switch betwin 6 tabs ( or 6 different transformers ) , between each tab we have 5 V , so the max power that we will dissipate is 50W ( maby a little more ) there for I don't need a huge heat sink ( even maby a little CPU one with temp controlled fan ( and of course over temp protection ) . well I don't know when I'll be able to build all of this stuff ( find the transformer/s it's very difficult ) but I know I will , so I might post here the whole proses of building this power supply .
Oh and I saw a "hold" mode ( short 2 pads ) , is this "hold" function is like every multi meter ?
have a nice day !
