this is what im trying to do with two strong magnets from a 3.5" HD; still no luck
Even with one HDD magnet it should be easy to saturate the tip. Set the iron down on a safe surface, hold it with something heavy maybe, just bring the HDD magnet up beside it and the power will drop.
In this case 23W -> 16W.
If you want to compare to the idle power of just the station, unplug the tip and measure.
Thank you for Kindly responding as always
Since I don’t have a wattmeter, I measured the current (rms) at nominal 240V (232rms to be exact), as follows:
1) SP-200 heating up at 212mA then settles at 90mA
2) SP-200 in the Workstand of the WS1 of MFR-1110, 83mA … knowing that WS1 is not optimized for the SSC cartridge.
3) MFR-1110 heating up at 420mA and settles at 150mA
4) MFR-1110 in its WS1 Workstand, 124mA
Now, bringing the SSC cartridge of SP-200 as close as possible, approx. 0.5-1mm, to one HDD from the 3.5” disc drive, the current sinks to 83mA which is approximately the same as in the WS1.
My conclusion is two fold:
- the power saving isn’t much, certainly not 50%, after the first phase of heating up has finished.
- the DIY magnet should be very close to the cartridge to the cartridge (to achieve a high field strength), which poses a construction challenge. The wisdom is, should I need an auto sleep Workstand for the SP-200, it’s probably better to spend CHF 40.- and buy the WS2 from Farnell
Thanks
