Author Topic: Radio Shack Digital Soldering Station 64-053 Atten AT209D Harbor Freight 96531  (Read 10320 times)
Offline jakeisprobablyTopic starter
    • Upcycle Electronics
Fred Flintstone's Internet Connection Beware lots of pictures here!
I am going to try to make this information as clear as possible to help anyone find information about this device. There is another, very old thread here about this subject but it was not very clear IMO.
What is it really
   All of these 60w digital soldering stations are made by a single company, Atten. The product is then rebranded for other stores/brand labels. Atten offers other watt ratings within this model line but the most common one that gets rebranded is the 60w.
The Design Details
   The iron uses a Hakko 900m tip. The iron itself (just the handle part) looks like a Hakko 936. It is NOT the same, and they are NOT interchangeable. Hakko uses a 5 wire heating element. The 5 wire PLUG is used on the Atten 60w. The Atten circuit only uses 3 connections inside this 5 wire plug. The Hakko 5 wire system has a heating element on 2 wires, a temperature sensing thermocouple element on 2 wires, and the earth ground wire in the center. The Atten unit uses the thermocouple in series with the heating element to determine temperature. This design has only 3 connections, two for the element and one for ground. The heating element dimensions are the same as the Hakko 936 (around 69-70mm from glass sleeve base to tip × 3.7mm main body). The iron's body and all it's respective parts and connections are compatible(the wiring is not).
   The original unit I have from RadioShack has a resistance of 10.2ohms at room temperature. With Harbor Freight digital calipers the element's wire diameter is 0.62mm.
  The cheap (<$5) 936 clone iron I have measures 13.7ohms at room temperature and uses a wire diameter of 0.32mm, on one set of connections, 0.0ohms on the second set of wires w/ the same diameter wire used.
  The temperature sensing is done by passing a signal through a LM324 op amp, that is connected to a PIC16F688 MCU. There is no programming header for the MCU but the DIP IC is socketed.
   I have not reverse engineered this circuit, nor do I plan to.
However, a few interesting notes on the Hardware:
BC547×3 transistors
BT136 600E ×1 (on heatsink)
CJ 78L05 ×1 reg
CJ 79L05 ×1 reg negative
LM324N (Ti)
P102 ×1 (1k trim pot -adjusted/painted(LCD Backlight?)
P103 ×1 (10k trim pot -adjusted/painted)
1k Potentiometer ×1
2×8 LCD Hitachi Character Style
5 pin Aviation style plug
Banana terminal grounded to mains earth ground
Nicon 1000uF 25v KME ×1
Nicon  470uF 25v KME ×1
Nicon    10uF 16v KME ×2
Inline Threaded Fuse Holder w/500mA standard 20mm×5mm glass fuse (white secondary line/must disassemble to access)
Primary Mains Fuse Holder (on bottom) w/630mA standard 20mm×5mm glass fuse
Transformer Labelled:
Shenzhen Xiongying Electronic Factory
Model: XY-360030
I/P: 120V AC 60Hz (red-red(connecting wires))
O/P: 29V AC 1.92A (blue-blue)
           9V AC 0.2A (white-white)
To open the unit, four screws hold the main enclosure together. Two are hidden under the rear pads. The wiring on the switch is mounted with the wider terminals down. The two lower/wider connectors connect to the two red wires with spade connectors (transformer primary side wires). The upper 2 terminals of the switch are connected to the white wire with spade connector (mains neutral), and the blue wire with spade connector (mains hot wire from primary fuse holder).
  There are 3 identical 2 wire connectors on the PCB. The one closest to the center of the PCB is White/White, the middle is Red/Black, the outside connection is Blue/Blue.
The old Radio Shack part number for conical replacement tips for this unit is 64-2114.
The packaging was marked:
RadioShack Conical Soldering Tip 900M-T-LB
More details: Compatible with Hakko, medium 900M, 900M-ESD, 907, 907-ESD, 933 models
« Last Edit: August 15, 2017, 09:19:32 pm by jakeisprobably »
I just came across a tear down and reverse engineered analysis of a similar Atten circuit design. It's not identical but Roger does an excellent job of breaking down the analog temperature circuit on his KainkaLabs YouTube channel. If you want to understand this device these videos are a must watch (I have no affiliation or financial motivation)
https://youtu.be/phDOs18MbRs
https://youtu.be/hQY4sKDlp3I
« Last Edit: August 16, 2017, 12:14:47 am by jakeisprobably »
Offline amyk
I don't think the thermocouple is actually used in series with the element; the middle is the common connection of the two (circuit ground, not ESD ground.)
That said, there is an Atten design station that truly uses a 2-connection element+thermocouple, but the handle is not a 936 style on that one and the wattage was something like 120W if I remember correctly.
  I'm just a hobbyist and am not very smart. This type of circuit is outside of my depth. However, the explanation that Roger gave in the second video I quoted above, went into depth about the two design possibilities of a series thermocouple or a design that uses a resistance measurement. His unit from the video above appears to be a very similar unit. I am no expert by any means, but his testing and explanation were really convincing to me when he showed the thermal voltage present after powering off the element and explaining it's significance.
 In my best attempt to verify the possibility of 2 different versions of this heating element I used Google chrome to try to search the Chinese Atten website for replacement heating elements. They do not show any variation of a 60w ceramic type element. The Chinese Atten website has a fairly thorough list of supporting products and accessories. http://www.atten.com.cn/PJL/
   Perhaps I am missing something though, again, I'm no expert.
Edit:
  Roger shows the thermal voltage versus resistance measurements starting at 7:35 on the second video of my previous post.
   He then describes how he reverse engineered everything. If you want to skip to the analog circuit breakdown he goes into that at around 26:30.
« Last Edit: August 17, 2017, 05:08:28 am by jakeisprobably »
Offline Shock
Offline ceramic
hello, hope everyone is doing well...
for whoever is interested in the LCD display setting, it is indeed the mentioned P3 potentiometer.
setting it too hot makes the display appear ?burned?. i will attach a pic of the display showing how it appears with the P3 set too high.
hopefully this will be useful for other users, as i have in fact disassembled the display assuming there's a mechanical/electrical issue (gently pressing it thru the window does produce a similar effect as the P3 pot being set too high so i assumed the retaining bracket is pressing it too hard...).
for search purposes: "Radio Shack soldering station 64-053 display setting", "RadioShack soldering station 64-053 LCD adjustment", "RadioShack soldering station 64-053 burned LCD display"
« Last Edit: June 26, 2025, 11:26:19 pm by ceramic »
