Hello everyone,
with the newer board revisions with large EEPROM, I discovered that every new label SKU that isn't yet stored in the EEPROM must be saved to the EEPROM once. Otherwise, the DMO will flash, and you'll get an error message in the program.
This means you have to disable the read-only-mode (remove the solder blob on the EEPROM, it's better here to solder in a switch , two wires that can be twisted together or similar).
Insert the unknown original label you want to learn to the DMO or the unknown SKU from the bluepill, turn on the DMO (DMO shouldn't blink with read-only disabled), print a test label, turn off the DMO, and switch back to read-only mode (solder blob or similar). This has to be done with every unknown SKU.
For those who new install the bluepill to their DMO, install first the bluepill with the choosen SKU, print one or two bluepill-emulated-labels, if this works then
enable/ switch on read-only-mode on the EEPROM, one step before the other results in a non working flashing DMO (if the label SKU is not in the EEPROM).
