Author Topic: Dyson v7 Trigger cordless vacuum - TEARDOWN of battery pack  (Read 200743 times)
Offline ruddlescounty
Re: Dyson v7 Trigger cordless vacuum - TEARDOWN of battery pack
« Reply #200 on: February 27, 2023, 05:22:57 pm »
Slightly related, sorry! with all the experience on here - does anyone know what the 10 red flashing light sequence means on the dyson SV03? i have balanced a battery previously refusing to charge; all looking good (reporting 1700mah capacity) but when i put it into the vacuum i get the 10x red. the batt still has its cover off and balancing cables soldered on - but i cant see any "body" switches inside to check for this.
so, just asking in case anyone knows...
Offline rulof
  • Country: ru
« Reply #201 on: February 28, 2023, 07:20:34 am »
apparently, a strong voltage drop during start-up. 10 red is an error in the charging process. if you replace the batteries should work fine.
« Reply #202 on: March 08, 2023, 05:56:42 pm »
thanks for the reply.
got a few of these dyson batteries.
Is there anywhere i can see a list of codes and meanings?
latest one is 10x BLUE flashes. this is after i have rewritten eeprom from a 32x red flash battery.
several balanced charge/discharge cycles later - all indicating approx 1550mAh capacity, i now get the 10xBlue when i press the battery button.
any ideas?
thx
Offline rulof
  • Country: ru
« Reply #203 on: March 09, 2023, 10:54:01 am »
any ideas?
thx
it's clear without ideas here.
it is necessary to replace the batteries.
Offline tinfever
  • I like to make life harder for myself
« Reply #204 on: March 09, 2023, 11:00:38 pm »
any ideas?
thx
I'm not sure you necessarily need to replace the cells. I'm not sure there is any good info out there on what the stock firmware LED codes mean, specifically. I'd check the Dyson manual for any clues and Google around but if you can't find any info on that blink code, it's possible no one knows. You could flash my custom firmware (FU-DYSON-BMS) to get more specific LED codes if you wanted. Also, make sure it isn't something simple like the battery needing to be plugged in due to a fully_discharged flag being set or something, or the battery turning itself off because it isn't seeing a large enough load. Other than that, it's possible your cell capacity is okay but the ESR is too high so as soon as you try to use it with a high current load like the vacuum, the cell voltage drops and it goes in to low voltage cutoff.
Offline rulof
  • Country: ru
« Reply #205 on: March 10, 2023, 11:30:37 am »
any ideas?
thx
I've tried it many times already. even with a capacity of 1800-1900 milliamps, the batteries do not pull like that. on your firmware, most likely there will be error 16.
Offline tinfever
« Reply #206 on: March 10, 2023, 10:06:50 pm »
I've uploaded Google Translate images of rulof's photos for anyone else.
Would you be able to share that entire document you took a picture of? It looks very useful.
Also, would you be able to measure the VBACK pin of the ISL94208 with a scope when the error 16 occurs on trigger pull on a bad battery? I'm curious if VBACK is dipping below 2V, and if it is dropping that low, I'm curious if adding at 10uF capacitor to the VBACK pin helps any.
My previous theory was that when the output is short circuited, the current wouldn't be enough to trip the short circuit protection but it would be enough to drop the battery cell voltage very low, causing the power to the VBACK pin to go too low, causing the ISL94208 to reset. In theory the same thing could happen with older battery cells with higher ESR when they aren't being short circuited but just subjected to inrush current demands. If my theory is correct, extra capacitance on the VBACK pin might let the ISL94208 ride though the inrush current voltage drop. This might also be why the ISL94208 reference design includes a 10uF cap there (which Dyson omitted).
Offline rulof
  • Country: ru
« Reply #207 on: March 11, 2023, 07:20:29 am »
currently out of stock with error 16. as soon as it appears, I will take measurements.
Offline bluesight
« Reply #208 on: March 13, 2023, 06:30:24 pm »
In case anyone is interested in an update on my progress. I found a really tricky hardware bug while working on the documentation, and it took me a couple days to figure it out and create a work around.
Current theory/procedure:
0) Directly short the output (or connect it to multiple electronic loads that appear as a short until they start to limit the current)
1) The trigger is pulled and output is enabled as usual
2) There is a massive current spike, but not so huge as to trip the short circuit protection (which has to be set to 175A because the next lowest step, 100A, is insufficient for vacuum startup).
3) The output is disabled, but probably not actually because short-circuit protection kicks in. It takes about 400us, vs the 190us for short circuit protection.
4) The ISL94208 RESETS ITSELF AND DOES NOT PROVIDE ANY ERROR FLAG. Thus it is not obvious what happened.
     - This is likely because during a hard short, there can be a current spike of 140A+.
     - This causes the voltage on VBACK (attached to cell 1) to drop as low as 1.46V (vs 3-4.2V normally).
     - VCC for the ISL94208, which is connected to Cell 6 drops as low as 10.5V but that's still above the POR voltage
     - This is below the listed typical POR voltage (no minimum provided) for VBACK and is likely causing the reset of the ISL, which wipes all registers.
     - All of this is likely caused because Dyson omitted the 10uF capacitor for VBACK shown in the ISL94208 datasheet (page 32).
5) The normal I2C commands to the ISL fail while it is resetting, causing I2C errors.
6) Previously, I2C errors were handled by resetting the PIC. So the PIC is reset.
7) The PIC starts up and sees the trigger is pulled and the ISL is presenting no error flags.
8 ) Wash, rinse, repeat. Go to step 1.
I've determined I can set some of the User Flag bits and periodically check those to determine of the ISL has silently reset itself. If those bits are cleared, it then asserts an ISL_BROWN_OUT error, rather than having the output flap. These User Flag bits also have to be checked in more than one place in the main loop because the ISL doesn't reset *immediately* after the output enable bit is set on a dead short, so if I check the User Flags immediately afterwards they'll still be fine. I also had to add more elaborate I2C error handling than just resetting the PIC since that would prevent the ability to detect that the ISL reset.
I also tried to assess how the stock batteries react to this fault. I blew the MOSFET and the fuse. Then I replaced the MOSFET and shorted out the fuse. Then the MOSFET blew up again (that could be due to my bad soldering though). At this point I decided I needed to not permanently destroy my last working V6 BMS board since I still need to test that my firmware is compatible with it. Most development was done with a V7 BMS board but it was designed to be compatible with V6 boards too. There are a few different versions of the V6 BMS board, so after I publish everything it would be helpful for anyone willing to test the firmware on a previously untested board version are report their results.
When I want to quit the program, it won't let me, and I get this message: System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\Microchip\PICkit 3 v3\PICkit3.ini' is denied.
The ZIP contains 3 other ZIPs, do I have to invoke those other files too in some way?
An I'm running Win7-64b.
Edit, it's running now, but still can't select the 16LF1847
Edit 2, can select it now, but still get the error while trying to quit.
I think that error when trying to close the PICKit 3 programmer program is "normal". I always get it too. You can thank Microchip for that.
I think I have this problem. I did your firmware update. Unfortunately, I may have done a short when fiddling the switch near the exposed posts. Firmware update successful with all blink/color codes working. Charge codes working. When in vacuum and pulling the trigger, I get the 16 red blink "brownout" code. Tested vacuum motor with external supply and it works. Did attach VDD at PIC program time. So multiple opportunities to glitch the ISL94208. If that's the problem, this post seems to indicate that the ISL can be reset (or not). I see in your code that you provide a reset segment...?
void ISL_Init(void){
    ISL_SetSpecificBits((uint8_t[]){WriteEnable, 5, 3}, 0b111);    //Set all three feature set, charge set, and discharge set write bits
    ISL_SetSpecificBits(ISL.FORCE_POR, 1);                          //Make sure the ISL is clean reset
So, is this the problem, and is it permanent or fixable?
Tnx!
Offline tinfever
« Reply #209 on: March 13, 2023, 07:29:50 pm »
Tnx!
For future reference, the dedicated forum thread would be the best place for questions like this: https://www.eevblog.com/forum/projects/fu-dyson-bms-an-(unofficial)-firmware-upgrade-for-dyson-v6v7-vacuum-bms/
If the battery is able to charge properly, I think the ISL94208 is working okay. I don't recall precisely what checks I run using the ISL94208 but I suspect at least one of them would fail if it wasn't operating. The PIC wouldn't run at all without the 3.3V from the ISL, and the ISL handles the multiplexing of all of the battery cell voltages so unless it got stuck reporting an identical valid result for every cell, the cell voltage checks wouldn't pass at all. Also, I just looked at the code again, the only way charging would work properly is if the ISL brown out check function passed, which would only work if the ISL is responding to I2C commands properly.
Please also check if the battery LEDs act normally if you press the button with the battery out of the vacuum with no load attached.
If that works fine, I suspect your battery cells have too high of an ESR and the load of the vacuum might be causing the cell voltage to drop enough to brown out the ISL. This is what rulof and I were discussing. I don't know what equipment you have but you could try to measure the battery ESR either with a battery tester, or by applying a known load and measuring the voltage drop. You could also try to measure the voltage drop on the VBACK pin of the ISL94208 during vacuum startup with an oscilloscope and see how far that voltage is dropping.
My current theory is that it is the inrush current of the vacuum triggering these errors on batteries with high cell ESR, but at least some batteries might be able to sustain the normal running current if we could ride through the inrush-caused-voltage-drop.
Offline PavChu
  • Country: by
« Reply #210 on: March 24, 2023, 07:00:36 pm »
Hello everyone, thank you for participating in this forum, especially the author of the custom firmware (FU-DYSON-BMS) and his colleagues and inspirers. This allows many people to solve their problems with batteries, as well as reduce the number of used batteries in the trash.
I want to ask the guys. Can PICkit 3.0 (when properly connected according to thewiring diagram) automatically not detect PIC16LF1847 on the 61462 PCB and the 188002 PCB. There are two non-working ones. The EEPROM is also not displayed in both cases. When the voltage is applied via PICkit 3.0 to a PCB that is not connected to the power elements, the indicator light reacts and changes color when the voltage changes from 2.5 to 5.0 V. When connecting the PCB to the elements, the LED indicator does not react in any way. I thought maybe the PIC16FLF1847 is just disabled somehow, maybe with MPLABX? In any case, Dzyakuyu syabry!
Offline tinfever
« Reply #211 on: March 24, 2023, 09:30:40 pm »
The latest recommendation is to not power the board with the PICKit and to leave the VCC wire disconnected. The battery should be able to power itself by pressing the button and applying a magnet to the reed switch if applicable. The PIC is a 3.3V version so you definitely shouldn't supply 5V. Any working board should be auto detected by the PICKit software I believe.
Offline PavChu
  • Country: by
« Reply #212 on: March 27, 2023, 05:34:16 am »
I got you, Tinfever! Thank you sincerely  :-+
Offline rulof
  • Country: ru
« Reply #213 on: May 11, 2023, 02:33:24 pm »
I have two dyson v10- sv17 batteries.
one is fully functional,
the other is blocked.
the atasamd20e15 processor is installed.
there is a programmer j link v9.
when connected, he wants to erase the firmware.
tell me is it possible to read and flash only eeprom?
by analogy with dyson v7-v8?
Offline deuteron
« Reply #214 on: May 29, 2023, 11:58:48 am »
Dear Alll,
first of all many many thanks to all, who have contributed to this extremely interesting thread ! The work of tinfever & co is absolutely marvelous ! I read the thread from the very beginning since I'm a 'proud' owner of a Dyson V8 (SV10). The device was sold with a working battery, but the preowner said it is running only about 20 min with the actual battery. After having learned so much about the interior of the dyson batteries, I was curious to examine mine in more detail too. I'm not planning to 'repair' the pack or to change the cells, it's just that I wanted to now what's wrong. So I drilled alltogether 12 holes in the two side walls of the casing to be able to measure the individual cell voltages. Against my suspicion the pack is balanced pretty well, showing voltage between 4.07 and 4.12 V with an average of 4.10 V  in the completely charged state, i.e. the charger stopped charging, all LEDs off. After all investigations done by various people about this batteries this behaviour was unexpected, at least to me. My imagination was so far that the charger charges the cells until the highest of them reaches 4.2 V, the unsual maximum voltage of Li ion cells. Ok, it's not much of a capacity which is unused in my case (got 24.5 instead of 25.2 V max). Nevertheless it looks like the charger doesn't use the full cell capacities. What do you think, could this be a fault from factoty, some bad adjustment of the parameters or even a 'feature' to sell faster and more batteries ?
What's your opinion ? Did you see such an behaviour in your battery packs too ?
Best regards
Stefan
Offline tinfever
« Reply #215 on: May 29, 2023, 04:48:04 pm »
Dear Alll,
Best regards
Stefan
20 minutes might actually be a normal run time. I don't recall what the vacuum is rated for when new. Even if that is actually low, I think it is normal for battery cells to have reduced capacity as they have more charge/discharge cycles on them.
I wouldn't worry about your pack only charging to 4.1V. It's possible on the V8 vacuums they charge to a lower voltage to preserve battery life. The ISL94208 BMS IC has an analog out tolerance of -15 to +30mV anyways, so it could just be error stacking. Also, once the battery is removed from the charger, I think it isn't uncommon for the voltage to drift down slightly, especially since the Dyson charging doesn't do a full constant voltage then constant current charge cycle. If you haven't already, I would watch the voltage on the highest cell when you connect the charger and see what it does.
Offline deuteron
« Reply #216 on: May 29, 2023, 06:31:06 pm »
Hi, thanks fpr the reply,
next, what I'll do is measuring the capacity of the pack, then we'll see whether or not the cells are weared in some way. These 20 min are just a guess, the seller told me, that the battery decreased in running time since he owned it. That's all I know. Is it possible that the charging voltage is programmed to decrease with time ? Frankly, I wouldn't believe.
Another question, maybe somebody knows: I was somewhat inspired by the discussion here to learn more about power tool batteries and the way these are BMSed. It seems to be the case, that usually there is no active balancing in most cases either. Dyson doesn't seem by far not the only company saving the extra money for a balanced charging. Also that the battery is blocked by the BMS in the case of a too strong unbalance is apparently not an exclusion. I'm just wondering what the special problem of the Dyson batteries is that they give up allready after about one or two years. Ok, the non resettable blocking via eeprom is some particular feature of the Dyson batteries. To my knowledge, resetting of a blocked power tool battery seems usually more simple. But this can not be the reason for this particulatly short running time. What is it ? Perhaps the max charging voltage intentionally diminishes with time (see above) ? Or did I overlook something else ?
Greetings
Stefan
Offline tinfever
« Reply #217 on: May 30, 2023, 03:49:45 am »
Greetings
Stefan
I doubt they do anything outright malicious like having the cell charging voltage reduce over time. It's probably just aging of the cell from the charge and discharge cycles I'd guess. Maybe power tools have a different usage profile that means the cells last longer? It's possible that most people's Dyson sits on the charger all day long which means it spends most of it's life at 100% charge, whereas maybe a power tool is only charged once empty? Maybe they just picked a different cell type? Perhaps the thought isn't right to start with? Maybe power tool batteries degrade the same but people are worse at counting number of screws driven on a charge vs number of minutes vacuumed on a charge? You'd need lots of data before considering declaring a trend in power tool vs vacuum battery life spans.
Offline deuteron
« Reply #218 on: May 30, 2023, 05:45:02 am »
Yes, Tinfever that's all true and yours are similar to my thoughts. The idea with the long time in a 100% state sounds reasonable. And it would be certainly true, if the charger wouldn't stop charging after reaching full state. But as you kow, it ceases charging after a couple of minutes. Nevertheless, beeing fully charged is not a good idea over long time storage. Concerning the cell inventory you should have much more experience than me, since you dismanteld lots of packs, right ? So far - at least for the price of a new pack - I'm believing, they are using first class (japanese) cells, but this might not be the truth. I personly wouldn't also think that they act maliciously in any way. Nevertheless, when you look throughl all the forums and the comments at Amazon, it's more or less purely the battery, about which people are complaning. My personally strongest concern is more the very thin strength of the plastik housing, which causes these vacuums to crack, and this mostly at the handles, where the strongest forces are applied while unsing them. It makes no sense to speculate any further. Yesterday I ordered ordered an electronic load at Amazon and we will see what the capacity will be.
BTW a good workaround seems to be the usage of a quality battery pack from a power tool. I'm using the uasual adapter from for the V8 with a fitting to the Bosch 18V cells. The 4Ah procore is working pretty well even it is only five instead of six cells.
I'll keep the forum informed, if somebody is interested,
sincerely,
Stefan
Offline deuteron
« Reply #219 on: May 31, 2023, 08:30:09 pm »
Hello All,
the electronic load, which I've ordered, arrived today. Tomorrow I'll do the first capacity measurement with the Dyson SV10 battery pack. Just one additional question, because I'll try not to brick the pack:
Is there any minimum output voltage, which may cause the BMS to lock when fallen below ? Otherwise I would try 15 V discharge minimum being 5 x 3V. Surely I will measure all the cell voltages individually through the discharge process, in order not to get too much of an unbalance. If somebody knows, please let me know
Stefan
Offline tinfever
« Reply #220 on: May 31, 2023, 09:29:37 pm »
Hello All,
Stefan
The vacuum normally runs until the BMS turns off the output when the voltage goes too low, so it doesn't matter what you set. Assuming you are leaving the BMS in the loop and not discharging the cells directly.
Offline deuteron
« Reply #221 on: June 03, 2023, 08:42:34 pm »
Hello,
just if someone is interested: I tested the capacity (at 3A) of the SV10 battery pack, about which the preowner told me that it is not as good as in the beginning. As said, cell balance was pretty good, max charging voltage ~4.1V in average. The meassurement (3.0V cut off on the weekest cell) resulted in a little bit more than 2000mAh. The pack is marked with 2800mAh on the casing. Ok, looks like some wear of the cells. But, the interesting thing is the following: I also own a (red blinking) SV10 pack gotten together with another V8. Since I didn't plan to reprogram it, I just took it apart th salvage the cells. These cells appear to be LG ones (LGDAHD2C1865) with a max current of 22A, so well suited for the Dysons consuming around 20A max. I googled for these cells and found the data sheet. The cells have a capacity rating of only 2100mAh even though 2800mAh is explicitly written on the casing of the pack ! This agrees well with my measurement and shows that the pack is practically like new, although used for more than one year.
In principle this is just another story about wrongly declared batteries from China. The interesting point here is that even Dyson itself doesn't seem to care about. I personly will stick to the power tool battery solution which is astonishingly working well even though the packs are only 18V.
Greetings
Stefan
Offline dax2
« Reply #222 on: July 09, 2023, 12:23:09 pm »
https://www.eevblog.com/forum/reviews/dyson-v7-trigger-cordless-vacuum-teardown-of-battery-pack/new/?topicseen#new
Looking that the settings options further, I see there are checkboxes for "Preserve Program Memory" and "Preserve ID Memory" that sound like could have prevented this. In hindsight I should have tested altering the EEPROM while leaving protected code untouched on my SV11(V7) BMS I've been programming first to make sure my settings were correct.
Hello tinfever, amazing job you did, on the good side your hard work it brings things closer and closer. I am pleasantly surprised you found the lockout algorithm, others can benefit and fix the balancing before putting the pack to charge.
It really sucks the MPLAB IPE settings are not very clear and there is only one chance of doing this, since the PIC accepts a full erase with no problem but no reading...
I hope the batteries you bought used are not the clones, those seems to last even shorter due to bad cells.
I know that being stubborn to find the solution, most of times pays off, as a sidetrack I just finished fixing a dead HP Pavilion 23xi display monitor found many months ago that was behaving strange... No wonder it was thrown away, other seems to have similar issues with this model. I bought the main chip and change-it, reprogram the Winbond 25x4 serial flash chip, changed the oscillator crystal... the monitor was not booting up... Just playing dead. I start to look around the resistors connected to the Winbond chip, one was bad, a 10k one was just open and the pin 7 - HOLD, the pin was floating low, chip was always going on HOLD because of that, no data,  so much work just for a stupid resistor... R54, circled. I leave this here in case someone googles for this issue on the HP 23xi series.
I took this work as a chance to practice my fine pitch soldering and the serial flash chip reprogramming, it was a while since I had not done this. I put the picture just for show off, my fine pitch manual soldering skills...  ^-^
Back to our subject, I hope you will receive your batteries soon to test the settings for lock bit re-programming. Meanwhile can you just load some garbage into the pic program area, set the read protect bit and then try to alter the eerom map and see if the program data is getting intact?
Since your chip is still working please try to find the exact settings of the MPLAb IPE so I will not erase mine when I will try to restore the lock bit.
Cheers
hi dvd4me - on your video someone posted they had modified the eeprom locations using IPE software (and pickit4 ?)  I am afraid to try and have succeeded using the standalone however I just spotted this option - is this Erase All setting not perhaps the problem?
Offline Manuel Wald
  • Country: at
« Reply #223 on: November 06, 2023, 08:40:06 am »
Hello everyone,
I couldn't find any other forum where the topic fits, so now I'm writing here.
I have already repaired some SV09 and SV11 batteries using Tinfieber's instructions, thank you very much.
Also carried out a cell replacement of defective cells and installed the new firmware with PICIT.
I now have several Dyson V7 batteries of type SV10 to repair.
Error flashes red 4 times, as described in the video, a battery flashes blue all the time!?
I balanced the cells to an even voltage and then used PICIT to rewrite the code according to the video.
Unfortunately the BMS is now without function, no LED display!
What can I do?
Is there a firmware that I can install on the others?
How do I repair the other batteries?
Thanks for your feedback!
Kind regards from Austria.
Manuel
Offline tinfever
« Reply #224 on: November 06, 2023, 05:08:20 pm »
Hello everyone,
What can I do?
Manuel
Some have reported that my firmware will work on SV10 batteries as well, although the LEDs may not be correct.
https://github.com/tinfever/FU-Dyson-BMS/issues/8
If you were trying to change the value in the EEPROM to reset the battery, you have to be very very careful to not erase the firmware in the process. There is a checkbox somewhere, IIRC, that if you don't set, it will erase the flash memory that contains the firmware when you try to overwrite the EEPROM. This would cause a battery to not respond or light up at all.
The following users thanked this post: harilaos
