Author Topic: Oval LED shape - Part Number  (Read 1898 times)
Offline 2XTopic starter
  • Country: gr
« on: February 23, 2018, 11:36:51 pm »
Hello,
I want to replace the below LED but I can't find it the same size. This led is from a home light and the space is extreme tight so I can't fit the classic 5mm LED. Aslo, this LED broduce much more light tha a classic water clear LED 5mm. Does anyone know where can I find a LED like this at the pictures? Thanks in advance.
Offline PedroDaGr8
  • A sociable geek chemist
Re: Oval LED shape - Part Number
« Reply #1 on: February 26, 2018, 04:59:45 pm »
Looks a bit like a low profile straw hat LED: https://shop.evilmadscientist.com/productsmenu/354
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
The following users thanked this post: 2X
  • Country: gr
« Reply #2 on: February 26, 2018, 07:46:34 pm »
Thank you very much. I ordered the below LEDs and I will tell impressions about the high brightness when I will receive them.
100pcs F5 5mm BLUE Straw Hat Superbright LED Light LED lamp GOOD QUALITY
https://www.aliexpress.com/item/100pcs-F5-5mm-BLUE-Straw-Hat-Superbright-LED-Light-LED-lamp-GOOD-QUALITY/32468997781.html?spm=a2g0s.9042311.0.0.qegUh6
