It was running off 25volts so I could take the photo 50 dies in total.
I said I would do some testing. Here are the results:
A warm white 50W Led module at:
34V drawing 1.24A = 42W
and
35.2V drawing 1.5A = 52.8W
So, why does the one I've tested appear to measure low?
Is it actually low, or is it an issue with my setup/power supply?
I'm using an ebay boost regulator, originally designed to go to 33volts, modified to be adjusted up to 34volts
As I don't have a suitable power supply...
Is it possible that ripple is throwing my measurements off?
