Products => Other Equipment & Products => Topic started by: artvandalai on October 04, 2024, 10:31:55 pm
Which is the better manual solder sucker to buy? Im between the Engineer ss-02 and the soldapullt sd017 or soldapullt ss350.
https://www.eevblog.com/forum/reviews/need-a-new-solder-sucker-suggestions/ (https://www.eevblog.com/forum/reviews/need-a-new-solder-sucker-suggestions/)
https://www.eevblog.com/forum/reviews/engineer-ss-02-soldering-review-awful-service-customer/ (https://www.eevblog.com/forum/reviews/engineer-ss-02-soldering-review-awful-service-customer/)
https://www.eevblog.com/forum/reviews/engineer-ss-02-solder-sucker-or-other-nice-desoldering-pumps/ (https://www.eevblog.com/forum/reviews/engineer-ss-02-solder-sucker-or-other-nice-desoldering-pumps/)
https://www.eevblog.com/forum/reviews/whats-a-good-solder-sucker/ (https://www.eevblog.com/forum/reviews/whats-a-good-solder-sucker/)
Good question. I've used the SS350, the SS-02 I bought after starting that thread that thm_w linked (wow, 10 years already?), and a ZD985 like the one Dave reviewed.
I don't think any of them are perfect or superior in every way to each other, and I think the lack of consensus in those threads will indicate that you'll need to try a few different tools to find the one that suites your application / technique / preference. Here are my 3 cents having gone through the motions:
Edsyn SS350:
Works ok, but I don't like how the tip is prone to melting and not a simple consumable like the SS-02's silicone tubing. Suction was also not enough for my taste. If I got another Edsyn, I would go for one of the larger / stronger ones.
Engineer SS-02:
Works maybe a little better than the SS350. The soft silicone hose tip is easy to change out and also lets you press into the board / joint to get a better seal. Tube diameter is a little narrow, so it feels more prone to jamming if you wick up a lot of flux. O-rings will degrade as others have complained, but you can buy an o-ring variety kit on Amazon for replacements. Not sure about the inner seal / wiper, might have to 3D print it if it goes bad.
ZD985 / Hakko type desoldering station:
This worked really well for quickly desoldering a large number of throughhole keyboard switches until it became clogged. I returned it because I couldn't find an easy way to keep it clean, might be a user issue. I see many updated versions of this station now, but they mostly use the same handpiece design inherited from the Hakko. The newer T12 units with the STM32 iron controller + separate vacuum look really interesting, I would get one if I wanted to try the vacuum + iron style again. (Also this thread (https://www.eevblog.com/forum/beginners/stm32-desoldering-gun/) made me lol, but I get the frustration.)
Overall, manual or automatic, you should be prepared to try multiple times and learn good technique to deal with various situations. The SS-02 is as fine a starting point as any, but don't expect magical results if you have big components attached to strong heatsinks (ground planes).
Edsyn Universal SOLDAPULLT US140.
I have used these for decades. They last forever, work extremely well, and are a FAR more reasonable size than the DS017. Not expensive for a made in USA product.
Replacement tips are also inexpensive and readily available. But unless you are desoldering for eight hours a day, it's unlikely that you'll ever need to change the tip.
https://www.edsyn.com/product/DHT/US140.html (https://www.edsyn.com/product/DHT/US140.html)
I use all sorts of solder suckers frequently.
Avoid the Engineer SS-02 if you are after heavy duty tool. It's a hobby level tool it doesn't last long. The trigger release parts is made out of alloy so after lots of use it will wear out. You can flip it and get another set of life but it will eventually wear out and you will need a lathe to make a new part. Another reason is that it's too small it causes fatigue quickly even for small hands. It's not that expensive, you can buy it and have a go. The small size means it's really good for a small portable service toolbox. Which is where mine lives now.
Have you tried placing silicon tubing on the Edsyn SS350? Wondering if the Edsyn SS350 is stronger than the SS-02 without the silicon tip?
Any comparison to the Edsyn SS350?
The Engineer SS-02 solder sucker SUCKS!!!
No serious, it's the best solder sucker I have ever used and owned.
In fact I have a spare in my drawer for if my beloved SS-02 ever fails.
Maintain your solder sucker, clean it regular and in time so it will not fail on you when you need it the most.
