Author Topic: EPROM Programmer - need a recommendation please  (Read 391 times)
Offline SolderSucker
« on: August 06, 2020, 03:30:32 pm »
I'm on the hunt for a USB-powered/interfaced programmer which will handle EPROMs of up to 42-pins (or even more). I don't want to spend a fortune but I also want one that's reliable and preferably has reasonable to good support from the manufacturer in the form of updates as required. A bonus would be if it also tests static RAMs and even TTL logic chips.
Any recommendations please?
Offline RomDump
Re: EPROM Programmer - need a recommendation please
« Reply #1 on: August 06, 2020, 06:06:28 pm »
I assume you aren't looking at the XGecu TL866II.
Then check out the Conitec Galep5. I don't think it tests TTL though.
RomDump
The following users thanked this post: SolderSucker
« Reply #2 on: August 07, 2020, 10:16:52 am »
Thanks, the Galep-5 is unfortunately rather expensive and, as you say, it won't test TTL or RAMs, the Chinese one you linked to won't test RAMs. I guess I'll have to try some cheap Chinese model with the required functions and hope it's okay.
Online sn4k3
  • Country: pt
« Reply #3 on: August 07, 2020, 03:54:28 pm »
At this point TL866II not worth when XGecu T56 is out.
XGecu T56 will test SRAM
56 Pin
Support chip model:
24/25/26/93 serial EEPROM, 27/28/29/36/37/39/49/50 EPROM, Paged EPROM,
FLASH memory (NOR, NAND, SPI NAND, EMMC, NVRAM, SRAM, CPLD (GAL), etc.
Support package: add DIP42/PLCC44/SOP44/QFP44/TSOP48/TSOP56/BGA48/BGA63/BGA64 /BGA100/BGA153/BGA162/BGA169/BGA221 on the basis of TL866II.
NAND EMMC supports maximum capacity up to 256G
Read full spec here and see if got what you looking for: http://forums.xgecu.com/redirect.php?tid=19&goto=lastpost#lastpost
