Author Topic: Getting WIFI for Ethernet-only devices  (Read 1967 times)
Offline Scutarius
« on: May 08, 2018, 03:56:56 pm »
I have many ethernet-only devices (cameras, printer, Recorders) it is unpractical to wire them all across the house so I am looking for cheaper alternatives to the TL-WR802N, this device works very straight forward, easy Client-mode configuration all in a compact case, without the power adapter.
Do you know any cheap reliable solution? one-board and no plastic case would be even better for me, thank you
Offline bob225
Re: Getting WIFI for Ethernet-only devices
« Reply #1 on: May 08, 2018, 04:27:25 pm »
most kit doesn't need full network bandwidth - powerline adapters work well in this situation - if you have multiple devices in the one location just add a hub (I have a powerline adapter behind our main tv with a 8 port gigabit switch that will happily do 120-200 MBs transfer to my nas)
The Wifi adapter whatever you use, will need is own power (usually 5V) either from a wallwart or full time powered usb port
eg.The netgear WNCE2001
Ethernet - Wifi adapters arnt cost affective for more than 1 or 2 devices - then you have the added issues if they fail to connect/freeze
tbh the lower cost of newer tech may out wiegh the cost of the adapters
« Last Edit: May 08, 2018, 04:38:48 pm by bob225 »
The following users thanked this post: Scutarius
Offline nhoj_yelbom
« Reply #2 on: May 24, 2018, 09:13:07 pm »
cheapest and most reliable by far imho
https://www.ubnt.com/accessories/airgateway/
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: May 24, 2018, 11:18:04 pm »
There are some very cheap routers that can run OpenWRT.
Offline thermistor-guy
« Reply #4 on: May 25, 2018, 12:49:43 am »
I've settled on Raspberry Pi as my "Swiss Army Knife" for network connectivity problems.
It's more expensive than the TL-WR802N, factory-new, but I seem to recall Top Loser has sold cheap rpi modules in the past, here on EEVblog.
Offline shteii01
« Reply #5 on: May 25, 2018, 08:42:43 am »
Maybe something like this: https://www.ebay.com/itm/TP-Link-AC750-Dual-Band-WiFi-Range-Extender-Extends-WiFi-to-Alexa-Smart-Home/192446235939?hash=item2cceb08523:g:7cUAAOSw5dlaTY8E
It got ethernet port so you can plug device there and the rest of the connection is wireless.
Offline Scutarius
« Reply #6 on: June 17, 2018, 01:57:21 am »
Hi, so far I have been using two TL-WR802N units, this is the right tool for the job, simple GUI, good range and fair price.
Thanks for your suggestions and comments.
« Last Edit: June 17, 2018, 01:59:11 am by CesarEscudero »
