Sorry I didn't realize, in fact one is called I-CON PICO MK2, and the other I-CON NANO MK2, in fact the nano is more expensive:
https://www.reichelt.com/it/it/shop/prodotto/stazione_di_saldatura_ersa_i-con_pico_mk2_68_w_1_canale-357477#closemodal
https://www.reichelt.com/it/it/shop/prodotto/stazione_di_saldatura_ersa_i-con_nano_mk2_68_w_1_canale-358235#closemodal
Both have 68w, on the outside they look the same, I don't know if the build quality changes between the two models.
The Pico and Nano are extremely close cousins, but I would not consider the
Nano Pico for electronics because the tip is not grounded. Someone who has used both says the Pico has stiffer cable on the iron, too.
And as already stated, the Nano is made in Germany, the Pico is made in China.
Hi, sorry just one question, can you tell me if the Ersa i-Con Nano and Nano Mk2 are powered by a linear transformer or a switching power supply ?
Hi. I haven't opened mine, but I bet it has a transformer (considering how unusually heavy the power supply section is)
The device weighs in about 1Kg, although it's mostly plastic (and the control board doesn't have anything heavy on it), so the weight should come from the transformer.
I also was hearing humming noises from pico (presumably coming from the transformer) but my nano is more quiet.
Weird. My Nano makes no sound at all.
Hi, sorry just one question, can you tell me if the Ersa i-Con Nano and Nano Mk2 are powered by a linear transformer or a switching power supply ? It does not use a cartridge system but from what I have read the performance is similar, even the tips I have seen that they are not expensive.
I have opened mine before, it's a transformer.
@Tooki
Do you also have an Ersa i-Con Nano soldering station ?
https://www.eevblog.com/forum/reviews/ersa-i-con-nano-and-nano-mk2-differences/msg5655303/#msg5655303
I wrote in my very first reply in this thread (reply #3):
Anyway, as someone who has a Mk1 i-Con nano at home, used Mk1 i-Con 1 and 2 at my previous workplace, and chose a Mk2 i-Con 2V for my current workplace: they’re all good.
That handpiece cable connection is just strange. Most soldering stations have a normal round connector.
That's because on the Nano and Pico, the handpiece is not intended to be disconnected, since there are no other handpieces for it. The connector is a card edge connector onto PCB fingers.
Did you get some additional tips?
Yes. It came with a Chisel 1.6mm tip as standard. I also ordered a Chisel 1mm, a Hoof 1.6mm and a pencil 0.5mm.
I suspect you'll find the 0.5mm pencil to get exactly zero use. Not only are tips that thin only useful in extremely limited situations, pencil tips just suck.
The 0.8mm asymmetrical chisel ('CDLF08
A) is stubbier and works better for getting heat in.
What I recommend unconditionally is the PLCC blade ('BDLF20), the 2.4mm asymmetrical chisel ('CDLF24
A), and a big chisel (like the 4.6 mm asymmetrical chisel ['CDLF46
A] or regular 5mm chisel ['CDLF50]) for heavy components like the mounting pins of rotary encoders, for big connectors like BNC, and for using with solder wick. The asymmetrical ones are fabulous for solder wick.
Learning wielding 2 soldering irons in both hands (with regular chisel tips) replaces many of JBC spacialty tips not available from Ersa and/or soldering tweezers. Also I find many JBC specialty tips more like wankery often designed as workaround for lack of soldering skill, lack of proper design for production, or chosing wrong tool for the job (soldering iron) to begin with.
I absolutely do use two irons sometimes (that's why I ordered the i-Con 2V at work instead of the 1V).
But as for the rest of your reply, I wholeheartedtly disagree, whether with the statement as such, or with how judgmental the entire reply is.
It's not "wankery" to use tools that reduce the required operator skill, it's a sound decision for production. A "proper design for production" may not be possible for a prototype or short-run products. But even if a manufacturer or engineer does fuck up and make a bad design: what's wrong with creating workarounds to help a customer with a weird problem they have? How does it reflect poorly on JBC that they help their customers solve problems?!?
Some of the special tips are extremely specialized, like the ones for melting down heat stakes. You don't want to ruin your soldering tips doing that, and they plate those differently.
In a nutshell: just because those tips aren't useful to
you doesn't mean they aren't useful to someone else.
The one JBC tip I wish Ersa would copy: the other PLCC blades (which JBC calls "knives", since they yse the word "blades" for something else). In particular, the miniature C245789 is extemely useful for reworking QFN devices.
