I can comment only on TOMZN breaker. I ordered 2 contactors (switching relays), one got installed (25A NO/NC), another is noname current/power/voltage meter.
Voltage meter (however it was after power regulator, which cuts off parts of a sine wave AC signal) was about the same as measured with UNI-T UT210E meter (measured voltage and current).
25A relay is noisy during switch on (never had those type of relays, may be it is normal).
TOMZN was a deliberate choice of the brand since I've seen reviews and inners of their components, which seems to be OK.
