Author Topic: Favorite Metcal tip for 0.4 and 0.5mm pin spacing?  (Read 1369 times)
Offline JesterTopic starter
« on: November 29, 2021, 09:59:11 pm »
For those with Metcal soldering irons....
I'm curious as to your favorite tip for soldering 0.4 and 0.5mm packages?
I usually use STTC-145   (.016" Bevel Solder Tip)
I also like the EBM7SB275 (0.4mm 30 deg bent sharp tip), for most other relatively small stuff
Online oPossum
Re: Favorite Metcal tip for 0.4 and 0.5mm pin spacing?
« Reply #1 on: November 29, 2021, 10:02:36 pm »
STTC-036 30° Chisel 2.5 mm
Offline thm_w
  • Non-expert
« Reply #2 on: November 30, 2021, 12:17:51 am »
What are we talking, TQFP-0.4mm or? QFN?
STTC-036 is what I did use. Its not as good for QFN though.
On the T12 I prefer to use T12-KU, a small knife tip, way better for QFN touch up.
The closest I can find is maybe M7DS035H, but, the end does not come to a sharp point as the T12-KU does.
The bevel stuff might be ok too, but, 0.016"/0.4mm is crazy small, to me those small tips are almost useless unless its for modwiring. I would want say 2-3mm bevel at least for soldering.
« Reply #3 on: November 30, 2021, 01:25:44 am »
Mostly TQFP, if I plan to hand solder QFN, I typically tweak the footprint with slightly longer pads to allow a fine tip to touch the pad. I don't have one of those knife edge tips, I'm going to get one to try, looks promising.
« Last Edit: November 30, 2021, 01:44:06 am by Jester »
Offline thm_w
  • Non-expert
« Reply #4 on: November 30, 2021, 09:53:52 pm »
Advantage of a sharp knife edge is you won't need to extend the pads very much.
For TQFP I would tend to use a fat tip and lots of flux. Drag solder. eg this looks like a 3-4mm bevel tip:
Online SteveyG
  • Soldering Equipment Guru
« Reply #5 on: November 30, 2021, 11:03:10 pm »
SMTC-1167 or 1147 work perfectly for me
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
