Author Topic: fiberglass pen ESD safe? abrasives & components  (Read 284 times)
Online coppercone2
« on: March 31, 2021, 08:10:09 pm »
so fiberglass scratch pens, i.e. https://www.newark.com/duratool/d02266/brush-pcb-cleaning-fibre-glass/dp/94T6354
Are these considered ESD safe if you are cleaning the part on a ESD mat with a wrist strap? Say you are cleaning a old oxidized sensitive FET
« Last Edit: April 01, 2021, 05:18:17 am by coppercone2 »
Offline bob91343
Re: fiberglass pen ESD safe?
« Reply #1 on: March 31, 2021, 10:54:38 pm »
It probably depends on what you do with the residue from the polishing.
Online coppercone2
« Reply #2 on: April 01, 2021, 05:07:46 am »
What do you mean? Naturally you would wipe it off with alcohol on a kimwipe.. but during the scrubbing is it making static?
Old fet + scrubbing.. is it going to get damaged? The idea is to clean up the leads so they stick well with solder.
I thought either that, or using steel wool.. which seems safe so long you have a wrist strap on. But it does not come on a nice pen.
How about fine sand paper or scotch brite pad for that regard? Sanding sponge? sand paper glued to a stick? cotton buds?
« Last Edit: April 01, 2021, 05:18:46 am by coppercone2 »
Offline tooki
Re: fiberglass pen ESD safe? abrasives & components
« Reply #3 on: April 01, 2021, 10:18:21 pm »
Just use the fiberglass pen with the component on your antistatic mat (put a sheet of bare metal in between if you’re worried about damaging the mat). Then the component is always essentially grounded, and so is the fiberglass itself as it constantly touches the mat.
Online coppercone2
« Reply #4 on: April 01, 2021, 10:37:52 pm »
I am not sure how well its grounded if there is some kind of rapid buildup, it would need to be connected to ground through a lower impedance possibly. I am wondering if anyone knows if it does
