I'm setting up a vintage gaming area, Win98/ old consoles. I have cleaned and lubed the drive drawer and cleaned the entire box. The issue is it takes a long time to read disks I changed the laser still the same issue. I put in a disk the drive spins up the laser flashes one time the drive spins for about 30 seconds and stops and then, nothing. It sits not spinning/no laser for about 50 seconds EVERY time. Then the disk spins up, instantly is found and plays. From what I have seen this should not take that long and the disk should spin up and play the first time. This is a 30001r if that helps.
