Author Topic: Flexible PCB prototypes, GBP50 per metre!  (Read 2075 times)
    • Mike's Electric Stuff
« on: March 05, 2015, 10:18:06 am »
Inkjet/plating process for cheap flex circuits :
http://cittechnology.com/flexible-circuits/manufacturing/pricing.html
Plastic substrate so needs to use low-temp solder, but wow!
Day Job: Mostly LEDs
Offline free_electron
    • SiliconValleyGarage
Re: Flexible PCB prototypes, GBP50 per metre!
« Reply #1 on: March 05, 2015, 12:44:36 pm »
Thats been around for a long time.
They print a silver or carbon particulate and then use an ion exchange process to 'grow' a layer on top of that.
Basially an inkjet printer followed by a plating process.
But : single sided only. No holes , no through hole plating. Fortunately reels of 0 ohm resistors are cheap.
« Reply #2 on: March 05, 2015, 01:36:41 pm »
Apparently their process is a bit different, and  uses Inkjet vs. screen printing so minimal tooling,
Maybe, but with online ordering, low tooling cost and in-house assembly?
« Reply #3 on: March 05, 2015, 02:56:54 pm »
oh yeah. they had that since day 1.
i have a demo foil form those guys somewhere. size of an a4 sheet.
it is inkjet printed but there is an additional chemical step.
if i recall you need to solder with bismuth ( low temp )
