Author Topic: Fluke 196c screen problem ( horizontal line)  (Read 11524 times)
Offline hugos31Topic starter
« on: February 26, 2012, 04:04:49 am »
« Last Edit: February 26, 2012, 04:06:54 am by hugos31 »
Re: Fluke 196c screen problem ( horizontal line)
« Reply #1 on: February 26, 2012, 04:16:16 am »
because this happens?        when all was happiness :
« Last Edit: February 26, 2012, 11:40:08 am by hugos31 »
« Reply #2 on: February 26, 2012, 04:29:22 am »
previously had a fluke 123.  I have bad luck with fluke :'(
« Reply #3 on: February 26, 2012, 04:37:11 am »
fluke is rubbish
« Last Edit: February 26, 2012, 11:33:15 am by hugos31 »
« Reply #4 on: February 26, 2012, 04:41:57 am »
   some suggestions made ??in the USA
« Last Edit: February 26, 2012, 04:45:05 am by hugos31 »
« Reply #5 on: February 26, 2012, 04:48:04 am »
196C fluke screens made ??in Japan
Offline muvideo
« Reply #7 on: February 26, 2012, 07:30:43 am »
Hello, you are unlucky :(
I don't know how they are made inside but the failure mode is the same I have
seen in many lcd screens with "heat seal" adhesive connector tape that failed.
The ones I "repaired" were lcd status monitor that worked in hot and high vibration enviroment.
Fabio.
Fabio Eboli.
Offline vtl
« Reply #8 on: February 26, 2012, 08:03:04 am »
Looks like a classic symptom of a bad flat flex ribbon cable. One of the traces on the cable may be faulty. If you open it up and flexing the cable gives you back the line then you know its the cable.
If it is the cable it may be possible to fix if you are able to srape away and expose some metal to solder over the break.
« Last Edit: February 26, 2012, 11:10:17 am by hugos31 »
alm
  • Guest
« Reply #10 on: February 26, 2012, 12:03:35 pm »
Based on that DIY audio thread, it seems that you can either try the fix described in that thread or send it to Joel. Assuming it's no longer in warranty.
« Reply #11 on: February 28, 2012, 12:15:09 pm »
the problem is due to excessive moisture, broke the seal thermal
Offline Mint.
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« Reply #12 on: February 28, 2012, 07:57:16 pm »
I've heard that things like that happen in TVs because of bad solder joints!
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline Monittosan
« Reply #13 on: November 05, 2014, 07:14:18 am »
you can rework the LCD ribbon cable with a soldering iron on its lowest temp setting.
The challenge is getting to the vertical ribbon cable as its behind the glass :(
when i have some time i'll try and find a solution for the vertical lines as its driving me mad  |O
Offline mecapower
« Reply #14 on: January 01, 2015, 10:31:13 pm »
hello everybody,
I'm new on the forum,i read it a lot, lot of amazing skill there, well, I find a fluke 123 like new condition for a really good price, but, it has the same yellowish strange spot has Monittosan's one but in the right bottom corner.
Does someone have an idea of how an monochrome LCD can turn in yellow?
How to change that?
Thanks a lot
cheers
Charles
