Author Topic: Found a UK workbench in the US. Can someone help me find a specs sheet?  (Read 275 times)
Offline Fulmir
I found a weird Workbench/Workstation. It's very clearly from the UK, and probably from the early 2000s, but it's in the United States. I'm trying to find a specs sheet or any additional info on the thing but so far I'm coming up completely empty, which is pretty weird.
Pictures are attached below. I didn't think to grab a shot of it but it has what are pretty clearly two ESD studs on the two right corners of the main work surface. It also appears to be adjustable by pulling up on the front of the bench and sliding it up and down, though I'm not positive that's how it works. Does anyone have any info on what this thing is, who made it, and what the specs are?
Pictures of the bench in question: https://imgur.com/a/CZce6Os
