Author Topic: Free software for homemade microscope  (Read 7421 times)
Offline regiscruzbrTopic starter
  • Country: br
« on: April 14, 2023, 04:05:01 am »
Hi everyone
I made my microscope based on that Eakins 180X C mount plus a 0.5 auxiliary objective lens from Aliexpress, it was intended to be cheap, so I attached it to a 720P Logitech webcam that I had around.
It's for my hobbyist weekend projects, so I 3D printed support with some adjustments and so far works great for me. Just need to figure out how to fix the lighting and I will be almost done.
Now I'm having a hard time with the software side, I'm using the standard Windows Camera app, it does the job, but it's too limited.
So I want to ask if you know any free software that could work better for a microscope, maybe with some functionalities that could make the work easier.
Offline Psi
Re: Free software for homemade microscope
« Reply #1 on: April 14, 2023, 05:20:54 am »
If you wanted to, and have a little coding experience, it wouldn't be that hard to write a simple windows app to display a USB camera feed.
Then edit the data to do zoom or whatever features you want.
« Last Edit: April 14, 2023, 05:22:29 am by Psi »
Offline Someone
    • send complaints here
« Reply #2 on: April 14, 2023, 05:28:36 am »
imagej / fiji
Offline ygi
« Reply #3 on: April 14, 2023, 10:11:43 am »
I use "IC measure" with my Eakins camera: https://www.theimagingsource.com/en-de/support/download/icmeasure-2.0.0.286/
It's free as in "not monetized", it's not open source if that's what you're looking for.
  • Country: br
« Reply #4 on: April 14, 2023, 05:46:35 pm »
Thank you all
I tested all the suggestions and the option that ygi mentioned is exactly what I was looking for, but unfortunately for a reason that I still haven't identified, the option to select the camera, doesn't work.
My camera does not appear to be selected, only the option to review photos.
I researched about creating a python script to work with my camera and it really doesn't seem to be difficult, I like Psi's suggestion too, I'll research a little more.
But if anyone else has any other suggestions, I'd love to hear them.
Thanks
Offline ygi
« Reply #5 on: April 15, 2023, 08:51:51 am »
S-EYE is another one. This one works with any generic USB camera (even works with thermal). The only caveat is to find a recent-ish version because it's generic Chinese software with no official webpage. Basically, you can easily find old 1.x versions here and there but the one you want is S-EYE 2.0.
Offline tai
« Reply #6 on: June 21, 2023, 04:57:47 am »
I'm using a similar setup, but using Raspberry Pi 1 with a cheap 5MP camera attached.
Advantage of this setup is that you can use HDMI passthrough mode of the Pi, using raspistill -k command. There is almost no delay unlike USB camera.
« Last Edit: June 21, 2023, 06:26:30 am by tai »
The following users thanked this post: artag, rteodor
Offline amr
« Reply #7 on: November 02, 2023, 08:55:30 am »
Hello. If you need it I have S-EYE version 2.0.5.851.
Offline aramo
« Reply #8 on: November 22, 2023, 10:48:46 pm »
I need this software. can I please have the .exe file? may I write you a message?
  • Country: br
« Reply #9 on: January 02, 2024, 10:49:18 pm »
Hellow everyone
I'm back to this project  ^-^
I found this software interesting, but I couldn't get it to recognize my camera, in the end I understood that it only analyzes images saved on the disk, so I kept it installed.
Excellent, this is exactly what I was looking for, it has all the features I need. I had a problem with msvcr100.dll in Windows 11 after installation, but this is how I resolved it: https://youtu.be/p5UF_aQloKQ?si=bKog1cbDw3HReFSB
Thank you very much my friend.  \$\Omega\$
Offline brambo123
« Reply #10 on: March 17, 2024, 01:21:16 pm »
For the people who are looking for the S-EYE software:
https://lapsun.com/Download.html
There is both a 1.x and 2.x version on that page.
At the moment the latest version appears to be 2.1.0.879 with modification date 2024-02-22.
The following users thanked this post: hasbihal
