I have a Bofa system, it's a flexible, semi-rigid type hose that clamps to the edge of my desk, which in turn connects to the filter / pump unit on the floor.
It works well enough. Most importantly, it doesn't get in the way when I'm soldering, so I do actually use it. Of course, it does actually filter the fumes out of the air, rather than just direct them away from the operator where they'd end up getting breathed in at a lower dose over a longer period of time.
The plastic of the hose has become rather brittle over time and I've had to reattach both ends. It's currently attached to the desk with help from some duct tape, ironically being used for exactly the purpose it was originally intended - and it works well enough that I don't feel any immediate need to replace the hose.
