Pinout for c120 is identical with c210. short between 5 and 6 pin. The station sees the tweezers as c210.
The c120 cartridges are left and right side, but essentially it is a c210 cartridge.
You need to choose the cartridges as close as possible to the operating temperature (use soldering thermometer) , and to reduce the target power a little, the resistance still becomes half as much, and the current is 2 times greater.
The station measures the current (voltage drop across the shunt) , knowing the target power and voltage, and limits the power using PWM modulation (TC22 and HC24). Аnd based on this it calculates the resistance of the heater.
It is not recommended to use the c210 and c120 on the same station (e.g. an electronic switch for multiple handles) so that you do not have to constantly adjust the desired power when changing handles.
The problem is that in the thermocouple c115, c210 and c120 the seebeck coefficient (uV/C) is much steeper than c245,c470 and t12 and separately the cartridges are much less thermally inert due to their smaller mass, the station has to correct the current power much faster.
It should take more measurements of the current temperature per second, perform filtration, and adjust the current power supplied to the heater.
For this purpose, not one but 2 or 3 separate ADCs with DMA in the microcontroller (MCU) are used.
