Author Topic: Good quality chineese soldering station  (Read 11643 times)
Offline ststefanov13
  • Country: bg
Re: Good quality chineese soldering station
« Reply #25 on: November 19, 2024, 06:54:08 am »
I bought a GEEBOON TC22 soldering station (C115 handle) and a GEEBOON SW03 switch at the same time. had colleagues bought TC22 (C210 handle), TC22 (C245) . I need the wiring of the handles to modify mine. I have AIXUN handles, but as far as I know the wiring is different for example AIXUN C115 has a resistor in the connector and help to correctly identify the handle from T3B station.
The seller is silent like a partisan when questioned about the wiring, the station according to the description should also be connected to a T12 handle, but how to wire it?
Thanks in advance.
« Last Edit: November 19, 2024, 07:12:12 am by ststefanov13 »
  • Country: bg
« Reply #26 on: November 20, 2024, 12:08:17 am »
GEEBOON Ali seler finally answered my request for handles pinout );
« Last Edit: November 20, 2024, 07:58:03 am by ststefanov13 »
Offline Frtech
« Reply #27 on: November 20, 2024, 06:44:08 pm »
@ststefanov13
Can you post the original picture if it has a bette resolution? We can't read the screenshot...
  • Country: bg
« Reply #28 on: November 21, 2024, 12:33:30 am »
GEEBOON pinout high resolution.
« Last Edit: November 21, 2024, 12:35:06 am by ststefanov13 »
The following users thanked this post: Frtech
Online MathWizard
« Reply #29 on: November 22, 2024, 11:58:05 pm »
I gave away my old soldering station, and now I wish still had it, so that I might try soldering really big stuff with both irons. I still have another, big old high power Weller tho, but IDK what tip's it takes, and it's dangerous to use on most stuff.
My old tip-style Hakko is doing great, and the cheap tips I got somewhere, are doing fine too.
I really want to get a small, touch-up iron, that could probably be power from 5V USB, or I'm sure I've seen cordless ones too. Just for tiny solder jobs, away from the bench, or in a tight spot.
