Thanks allanw,
You are very right about the 2465B! I know a respected designer and he only uses analog Tek models on his bench, he has said the same thing. Also think I might want a single sweep since I'm not going digital.
So besides the scope.
I'd like to design a mic-pre custom build for a specific mic that has 1.12mV output at 94dB SPL, and that's open circuit voltage, this means only about 4uA at moderate SPL through a 300ohm 1/1 transformer (I don't want to bridge). How in the hell do you characterize and learn from what's happening at your input, before amplification, when values are this low? What type of resolution and accuracy do I really need to in order to trust and learn form measurements? I like the Tektronix DMM4050 but am uncertain, your thoughts? Any info would be appreciated.
