Author Topic: Good quality chineese soldering station  (Read 6197 times)
Offline wonsTopic starter
  • Country: by
« on: August 12, 2023, 02:10:11 pm »
Hey guys
At work i use the jbc soldering station and i realy like it - so i decided to buy a clone .
After watching some video reviews i bought the SUGON clone that turned to be a total crap that except for looking and feeling nice - it couldnt heatup or maintain temperature at all
So any recomendations for other jbc clone that could be used for fine work like 0402 0603 but also can heatup and tin coat small poligons?
And if posible that could use original jbc catridges?
Offline Psi
Re: Good quality chineese soldering station
« Reply #1 on: August 12, 2023, 02:38:07 pm »
When buying clone irons, it's a good idea to pick one that uses the same tip format as genuine ones.
That way you can put a genuine tip on it.
Normally what makes an iron work well is the tip coatings and quality.
I've used a few china irons over the years and unit assembly / quality control, and tip quality are almost all of the problems you encounter. Also good idea to check grounding and ensure the power switch is on the phase line.
If I had to guess, your one not getting hot enough is probably an assembly problem. Dry solder joint or bad connector or something.
The following users thanked this post: wraper, marhuum
Offline tatel
« Reply #2 on: August 12, 2023, 03:27:50 pm »
Any T12 from KSGER or Quicko with a real STM32 on it. So you can use David Alfa's custom firmware. You can mod it to work with JBC handles, it's said it's not dificult. They have enough power to work with SMD components. You could also try original T12 Hakko tips without any modding. Pushing the adjustments in that custom firmware and using a D52 tip will allow you to solder almost anything. I'm happy with my quicko and Hakko T12 clone tips.
https://www.eevblog.com/forum/reviews/stm32-oled-digital-soldering-station-for-t12-handle/msg4993726/#msg4993726
Offline Swake
« Reply #3 on: August 13, 2023, 09:50:34 pm »
Check out the AIXUN T3B
Has several handle sizes such as T115 and T210
Fits the original JBC tips too.
When it fits stop using the hammer
Offline mastershake
« Reply #4 on: August 14, 2023, 12:41:52 pm »
as far as ones from china the aixun ones are hands down the best imo out there. and the 420 series is the best of them. but the a and b models work excellent. i also have the sugon and hated it i gave it away if im being honest when i compared it to the aixun. my favorite of them is the 420d. but really any of the aixun ones work very well and they have most if not all of the bugs by now worked out of them firmware wise.
The following users thanked this post: marhuum
Offline thm_w
  • Non-expert
« Reply #5 on: August 14, 2023, 08:29:40 pm »
Sugon should be decent,
Did you try your genuine JBC tips in it?
Did you calibrate the temperature?
Offline Psi
« Reply #6 on: August 15, 2023, 11:43:57 am »
It's pretty likely his one has some sort of a fault. Intermittent or otherwise.
Offline vulkan35
  • Country: ru
« Reply #7 on: August 16, 2023, 09:41:00 am »
GEEBOON TC20A 240W  JBC C245, C210, C115, Hakko T12  TC20A
GEEBOON TC20B 380W  JBC C470, C245, C210, C115, Hakko T12 TC20B
Aixun to the trash....  :-DD
Offline ilkinandr92
« Reply #8 on: August 19, 2023, 05:15:07 am »
Where can you buy this one?
Offline vulkan35
  • Country: ru
« Reply #9 on: August 19, 2023, 05:55:04 am »
Offline ilkinandr92
« Reply #10 on: August 19, 2023, 07:25:26 am »
Missed that, thank you.
Do you have one by any chance and do you know if it support 110v?
Offline vulkan35
  • Country: ru
« Reply #11 on: August 19, 2023, 11:06:26 am »
GEEBOON TC20B 380W supply power Li-ion 18650.
Online wraper
  • Country: lv
« Reply #12 on: August 19, 2023, 11:26:16 am »
When JBC clone sucks, you should change the cartridges to something better, preferably original. Unless station outputs lower voltage (unlikely), there should be no large difference in performance. If you use the same crap cartridges on original JBC station, most likely the result will be exactly the same.
Offline bitwelder
« Reply #13 on: August 19, 2023, 12:42:54 pm »
I'd guess those Geeboon stations will have one more "evolution" round before they will start to appear also on Aliexpress, under plenty of new brandnames
Offline slavoy
« Reply #14 on: August 19, 2023, 12:50:00 pm »
AiXun T420D is the best-made Chinese soldering station in the JBC style that I've seen so far. It also has manufacturer support and frequent, easy firmware updates, which is uncommon for such equipment from China. There is cheaper single-channel version available (T420) if you don't need the dual workstation.
Offline vulkan35
  • Country: ru
« Reply #15 on: August 19, 2023, 01:47:46 pm »
 :-DD  :palm: when I saw her for the first time I laughed for a long time. it looks like a soap dishes.  :-DD
Online jonpaul
« Reply #16 on: August 21, 2023, 01:45:07 pm »
"Good quality ...Chinese"
Oxymoron
j
Jean-Paul  the Internet Dinosaur
Online wraper
  • Country: lv
« Reply #17 on: August 21, 2023, 02:19:28 pm »
Oxymoron
j
Holier than though...oron. Chinese produce quite a bit of top notch or even best in class equipment even with domestic R&D (DJI drones for example).
The following users thanked this post: all_repair, janoc, thm_w, AmnevaR
Online wraper
  • Country: lv
« Reply #18 on: August 21, 2023, 03:04:41 pm »
I'll stress that this thread looks stupid to me. All discussion about station itself and total disregard to cartridges which were used (except Psi). Those are where 90% of performance comes from. From what I've seen, SUGON is completely OK and works almost as original JBC when original cartridges are used.
Offline Arts
« Reply #19 on: August 22, 2023, 01:53:20 am »
I liked the JBC soldering station so much I bought a real one.
Offline Yellofriend
  • Country: hk
« Reply #20 on: October 14, 2023, 01:17:45 am »
I'll stress that this thread looks stupid to me. All discussion about station itself and total disregard to cartridges which were used ....
I disagree. Because you always buy a original JBC tip, but you are stuck with the station. I am in the same boat right now with two stations using the Hakko 900M type tip. IMHO both underperform.
Currently looking into:
KSGER STM32 V3.1S
+Cheap <$50
- Can use only T12 (should be enough actually)
AIXUN T3A
+JBC clone stand (optional)
+ Great review
- Well over $100
Geeboon TC20A
+ Well below $50
+ Can use T20, C245, C210, C115 handles/tips
- No reviews yet
- Can't find outside Taobao
AIFEN / 爱风 A9pro
+ with holder
+ can set 3 temps
+ well below $100
- No T12 (but C***)
All price ideas from Taobao.com
The Geeboon looks tempting, the Ksger is sort of well known for years and similar priced. I think I will go with the Geeboon.
Update:  Geeboon TC20A - first impression
Ordered Saturday, received Monday. Not too bad ;-) Well packed.
Surprise 1: The paper manual has English!
Surprise 2: The stand does not suit T12 tips. Stand too short, part holes too small, and worst - bottom not flat, it wobbles (which is not a big deal since it can't be used anyway)
https://streamable.com/6vf7jy
Station works and can be set to English. I think I will buy also the other handpieces, C210 etc, need to have a look.
After using it for a while.....
  • Their website is https://geeboon.com (not much to see)
  • The heat-up time to 350°C is about 20-30 Seconds (that is when the solder on a T12 tipp melts) - seems slow, or?
  • The sleep mode on the supplied T12 hand piece is not very sensitive and it switches off while I work (switch off time can be set or disabled)
« Last Edit: November 09, 2023, 06:44:56 am by Yellofriend »
TVM802C - now with OpenPnP
T962A
Offline lastone
« Reply #21 on: December 06, 2023, 10:59:43 pm »
I ordered the bigger one, we'll see how it goes.
