Author Topic: minipro error "out of address of the device" Intel Hex file load for 2764  (Read 3033 times)
Offline shankaranvTopic starter
  • Country: in
  • "Keep it Simple Stupid"
Hi, I have recently brought TL866 programer with comes with minipro software. I am unable to open and load the buffer an Intel Hex file to program EPROM 2764 or 27128.
I am prompted with an error "out of address of the device" while trying to open a file with less than 200 bytes of code.
Has anyone encountered such an error? or is there some setting I am missing???
I have attached the hex file for reference.
Surprisingly when I select the eprom 27512 it gets loaded.
shankaran
Offline stj
that hex file is BS, it has more than one datablock - it looks more like it's intended for a microcontroller.
mind if i ask where it came from?
  • Country: in
I got the solution yesterday. I shifted the data segment (ie the RAM location at 4000h)to the end of the file and the miniprog loaded the code space but gave out of device memory error when it encountered the data space...but it is ok I can now program the eprom.
Just a background...
I am modifying an 1988 design based on z80 CPU to include a serial interface using 16c550. The original assembly programs were developed using X80 assemblers which can run only on win98 desktops. The hexfile is the linker output of the following program
UART_BaseAddr equ 0E000h
.code
            org 0
        nop
        nop
        nop
        jp main
        nop
        nop
    org 40h
   main:
        ld sp,4400h
        im 2
        DI          ;diable interrupts
        ld a,04h
        ld i,a
        ld a,30h
        out (p0),a
        call UART_INIT   ; Initialise the 16C550 here
TransmitAgain: nop
        call UART_Transmit   ; send initialised serial data to Arduino
        jr TransmitAgain
;                       Subroutine Serial Initialisation
; Input:     none
; Task:      Initialise the UART for baud rate of 9600
; Output:
UART_INIT:   nop
      ld ix,UART_BaseAddr
      ld (ix+03),80h      ; enable DLAB bit to program divisor for 4800 baudrate
      ld (ix+00),18h      ; 16 bit divisor LSB = 18H ie 24Decimal
      ld (ix+01),00      ; divisor MSB = 00
      ld (ix+03),03      ; now turn off the DLAB bit and program for 8 bitdata, 1 stop bit and no parity
      set 1,(ix+04)      ; Modem_Control_reg[1] = 1, ie RTS bit = 1 indicates UART is not ready to transmitting
      ld ix,SrBuffer   ; initialise the 32 byte serial buffer to 55h value
      ld b,32
NxtBuffLoc:   ld (ix+00),55h
      inc ix
      djnz NxtBuffLoc
      ld ix,SrErrorFlag
      ld (ix+00),00h      ; reset all serial error flags
      ret
;                       Subroutine:  Serial data Transmission
; Input:     none
; Task:      Serial Data transmission
; Output:
UART_Transmit:   nop
      push af
      push bc
      push de
      push hl
      push ix
      ld hl,SrBuffer
      ld b,32
      ld ix,SrErrorFlag
      res 0,(ix+00)
      ld ix,UART_BaseAddr
      res 1,(ix+04)      ;Modem_Control_reg[1], ie RTS bit = 0 indicates UART is ready to send information
      ld de,0FFFEh
Chk_RecReady:   bit 4,(ix+06)      ; Modem_Status_reg[4] ie CTS bit = 0, indicates that modem or external device is ready to exchange data.
      jr z,StartTransmit
      dec de
      jr nz,Chk_RecReady
      ld ix,SrErrorFlag
      set 1,(ix+00)      ; bit 1 denotes improper termination of serial transmission
      jr SrErr
StartTransmit:   ld a,(hl)
      ld (ix+00),a      ;send buffer contents to transmit FIFO
      inc hl
      djnz StartTransmit   ; loop until the 32 bytes are sent
chk_TrRegEmpty:   bit 6,(ix+05)      ; check if transmit buffer and transmit register are empty
      jr nz,chk_TrRegEmpty
SrErr:      set 1,(ix+04)      ;set rts bit to 1 to indicate end of transmission
      nop
      pop ix
      pop hl
      pop de
      pop bc
      pop af
      ret
;  Data Segment
.data
      org 4800h
;Serial interface with GM16C550
   SrBuffer: defs 32   ;reserve 32 bytes of ram for incomming data
   SrRecBuff: defs 32   ; reserve 32 bytes for outgoing data.
   SrErrorFlag: defs 1
   END
shankaran
Offline stj
that does not explain how you ened up with such a screwed hex file!
you should check your compiler or compile it to a binary file.
