Author Topic: Took apart my Tektronix DPO4034  (Read 11019 times)
Offline allanwTopic starter
    • Electronoblog
« on: November 20, 2010, 02:18:50 am »
a
« Last Edit: May 06, 2014, 06:20:41 pm by allanw »
Offline GeoffS
Re: Took apart my Tektronix DPO4034
« Reply #1 on: November 20, 2010, 05:07:58 am »
And the important question - did it still works when you put it back together?  ;D
alm
  • Guest
« Reply #2 on: November 20, 2010, 02:21:49 pm »
Thanks for the pics. Maybe the moisture sealant is to keep leakage low, so it lasts longer on the lithium cell?
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: November 20, 2010, 02:51:33 pm »
Awesome, and brave! of you.  Thanks for sharing.
Best Wishes,
 Saturation
    • Electronoblog
« Reply #4 on: November 20, 2010, 03:37:39 pm »
b
« Last Edit: May 06, 2014, 06:20:47 pm by allanw »
alm
  • Guest
« Reply #5 on: November 20, 2010, 03:48:47 pm »
I wonder what the chips marked 7SB42 D9DCG are? There are 8 on my scope, but there's enough lands for 16. This must be the ADC's, because the DPO4000 series goes from 2.5GS/s sampling to 5.0GS/s.
No hits on Google from the marking on the chip.
It sounds plausible that they're the ADC's, and in that case, it's quite likely that it's custom silicon. No manufacturer uses off-the-shelf ADC's, except in the very low end. This is part of what makes the faster scopes so expensive.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #6 on: November 20, 2010, 04:14:37 pm »
And what are these missing modules?
There's a total of 12 of them, in groups of four, scattered around the top of the board. Maybe it's for the MSO models with 16 digital lines?
I think these may be connectors for a high-speed logic analyser connection and/or MICTOR connectors - they appear to be grouped in differential pairs.
As regards the moisture sealant, this will be to avoid leakage due to board contamination on the RTC crystal's high impedance connections.
On the same subject, here are a couple of pics indide my Agilent MSO6034A :
« Last Edit: November 20, 2010, 04:20:14 pm by mikeselectricstuff »
Day Job: Mostly LEDs
Offline saturation
    • NIST
« Reply #7 on: November 20, 2010, 06:28:38 pm »
Wow.  For comparison, compare those boards to the Rigol 1052E, the integration and parts density of your scopes are intense.
From Dave's photos:
Best Wishes,
 Saturation
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #8 on: November 20, 2010, 07:01:00 pm »
whats the zigzag traces on mike's scope/pic? there are 2 big on the middle right (1st pic), middle left on the 2nd pic? looks funny.
ps: 3 last pics in the 1st post are broken. or isit just me?
« Last Edit: November 20, 2010, 07:31:09 pm by shafri »
Offline jahonen
« Reply #9 on: November 20, 2010, 07:06:26 pm »
Great, now I don't have to open mine. I like those high-speed length matched differential pairs :) Kind of amazing how both the Tek DPO4000 and Agilent MSO6000 have similar large lithium battery.
shafri: The zigzag is for length matching, to equalize the propagation delays on the PCB. A common high-speed technique.
Regards,
Janne
Online Mechatrommer
  • Country: my
« Reply #10 on: November 20, 2010, 07:34:55 pm »
hmm ok thanx. the heatsinks tell the story, not the usual rigol thing.
Offline scopeman
« Reply #11 on: November 20, 2010, 10:34:31 pm »
The moisture sealant area is to keep moisture and humidity from affecting the RTC and crystal for the time of day clock. Even a pF or so can change the frequency of the oscillator or cause it to stop.
Scopeman
W3OHM
Offline tinhead
« Reply #12 on: November 21, 2010, 08:53:26 am »
my theory : probably only "bank memory" chips, for 5GSs you will need second one "big" custom BGA soldered between these two Tek custom chip (without heatsink), so in principle two 2.5GSs ADCs,
each with 10M sample memory but together still "only" 10M memory but 5GSs.
