So I'm asking here for advice and recommendations for a rework/heat unit that can finish the job of delivering enough focused heat over a chip to finish the job of lifting it, without over heating neighbouring components... and on a budget, as I'm a hobyist. Let's say £50 just to ball park it, but I can be flexible. If recommended unit have good numbers of videos/documents to demonstrate how to use it properly and safely, then that's a very welcome bonus.
Do not buy the heaters with the fan in the handle. Just stay away.
Very loud, heavy and does not produce enough air. Prone to overheating and difficult to fix when the handle melts. It will definitely melt at some point because the fan does not produce enough air.
I recently tried Quick 957DW+ and I can fully recommend it.
https://www.tequipment.net/Quick/957DW+/Desoldering-Equipment/Rework-Stations/ sells it for $105 now with free shipment. Probaby US-only but not should not be very far from your budget even in UK.
It is much better than the old budget models:
1) All-metal case, pretty quiet, claims 580W.
2) Tool rest (magnetic) sensor in the handle! Will automatically cool down and stop when parked. I did not expect that for the price.
No fancy controls but does exactly what you would expect. I did not disassemble the handle so I don't know what's inside.
It's still cheap so do not expect anything fancy but I was very pleasantly surprised.
This is going to be an unnecessarily long one, just to get people to know where I'm going and what I need.
Firstly, I'm working on retro 8 bit machines and occasionally have to remove chips. Being on a budget I have a ZD-915 desoldering tool, but as you know it gets 95% there and leaves enough pins with a small amount of led solder on, to prevent the chip from lifting clean.
It obviously needs a small amount of directed heat to do enough melting to allow the chip to lift, but I'm having a heck of a job trying to find something. Obviously I've got larger heaters for removing mobile phone backs, but that's too large and delivers too much heat, to use on a 40 year old computer.
I did not have a chance to try ZD-915, but I own Hakko and old Aoyue tools. I also had a chance to try a similar high-end Metcal tool once. I feel that they are all the same in terms of performance, the difference is only in maintenance and available options.
In my experience none of them leave any significant (i.e. visible) amount of solder if you do it right. You need to make sure that the solder fully melts on the other side of the board. I usually look at the other side and wait for the pin to move freely around the hole before pressing the suction button. As you probably already know, there is usually a single chance to push the trigger.
If it did not work the first time you will have to add fresh solder and start over.
But usually it does not leave any solder residue. If it did then I made a mistake.
