Hi! //Because that's the only correct way to start a new post here!
So I've recently got the Conrad Elektronik LS-DIGI-60 soldering station. It's a bit old, mine is from '96 and I believe they introduced it in the early '90s, but it works perfectly. The only problem is that iron is in pretty bad shape and of course, there are no replacement parts anymore, so I have to fit something. I've done the research and measurements and that's what I found:
Supply voltage: 24V
Heater resistance: 10.6Ω
Temp. sensor: 1KΩ PTC
Plug: 5Pin DIN with standard (I believe) pinout - heater1, heater2, GND, temp1, temp2 (counting clockwise)
Max station power: 80W
So it seems that generic 75W Zhaoxin soldering iron replacement is a good fit however I am not sure about pinout, but this is not an issue. The bigger issue is that afaik it uses the thermocouple, not the thermistor, so the question is: Does anyone know any good fit replacement or should I go for Zhaoxin and modify it with replacing the temperature sensor?
Also, Russian Conrad claims that LK-60 is a replacement for that iron:
https://conrad.ru/catalog/payalniki/professionalnyy_payalnik_lk_60_dlya_ls_digi_60_/I couldn't find one anywhere on the west and with a reasonable price.
