Author Topic: High temperature thermal compound >500°C 932F  (Read 13464 times)
Offline nukieTopic starter
« on: March 08, 2016, 04:37:04 am »
Hi all,
Trying to improve thermal response of my old Hakko. I've been using thin aluminium shim as a spacer to fill void in between the ceramic heater and loose tips. I am thinking of using other material.
Nickel based anti seize - High temp, toxic?
Thermal compound Thermon T-99
http://www.thermon.com.au/products.aspx?prodid=138
This T-99 stuff is cool but heat transfer coefficient isn't the best. I also don't know where to buy this in very small amount. Smallest pack is 1gallon/3.79L.
Any other ideas?
« Last Edit: March 08, 2016, 04:39:26 am by nukie »
Offline Gyro
Re: High temperature thermal compound >500°C 932F
« Reply #1 on: March 08, 2016, 08:09:09 pm »
I'm just wondering about the copper grease that's used on brake calipers. A quick check of my local car spares website says -40C to +1150C. You ought to be able to get it in small tubes. The only question is whether it will be too messy (although it is designed to stay put and not spread onto the friction surfaces).
Best Regards, Chris
Online johansen
« Reply #2 on: March 09, 2016, 05:51:54 am »
how about a legit tip?
With a legitimate tip, you should have no problem soldering 4, 12 awg wires together. with a 1$ replacement tip, you will have to crank the Hakko up to 480C just to solder 2, 16 awg wires together in a reasonable amount of time.
it would not surprise me if a metal shim will decrease the heat transfer...
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: March 09, 2016, 05:16:46 pm »
Anti-seize seems the most likely candidate. Nickel, copper, moly D, probably doesn't much matter.
Be absolutely sure to keep it well away from anything that might possibly be conductive nearby.  I'm not sure how the stuff will flow (or not) once it's kind of baked into place.
Speaking of, most come with a grease base..?  So that'll bake out the first time, which is bound to be nasty.
+2 on getting a legit tip instead of making a mess.
Seven Transistor Labs, LLC
Offline mmagin
« Reply #4 on: March 09, 2016, 10:07:39 pm »
Maybe just melt some solder in there, as long as you're fine with never changing tips cold?  :)
Offline jkr
  • Country: gr
« Reply #5 on: September 05, 2016, 10:25:16 pm »
i'm using this TM600 30g Thermal Grease from here  :  http://www.ebay.com/itm/JERINGA-DE-PASTA-TERMICA-ORO-30-gr-SILICONA-CPU-XBOX-PS3-THERMAL-GREASE-GOLD-/321975256406  or here : http://www.thermoelectronic.com/pro-71-532.html , it's rated about 300°C but seems to be ok by now (just a week). if u find anything better let me know..
Offline robert574
« Reply #6 on: December 03, 2021, 06:20:52 pm »
Just saw this compound and remembered your post. Not sure if you found something already.
Thermal boron nitride paste good to 1000C.  Doesn't look too expensive.
Offline jpanhalt
« Reply #7 on: December 03, 2021, 07:38:20 pm »
Yes, it's an old thread.
BN is an interesting material, which is sometimes compared to a non-electrically conductive graphite.  It is also a nice dry lubricant.  However, at 500°C+ the problem is not BN, but whatever matrix it is loaded into.
Here's one of many studies: https://iopscience.iop.org/article/10.1088/1757-899X/394/2/022052/pdf
My interest was sparked by a need for a electrically insulating material.  Plus, its structure "BN" was intriguing.
Online coppercone2
« Reply #8 on: December 03, 2021, 09:10:11 pm »
aare you sure putting aluminum in there is not causing excessive strain on the heating element? Thermal expansion makes it tight and it could cause the ceramic to pop no?
