Well i have been eyeing this temperature meter for a long time, why?
Sometimes i really had enough of a DMM's built in temperature measurement. Okay, they go for 20$ @ DX (
http://dx.com/p/2-2-lcd-digital-thermometer-handheld-temperature-tester-1-x-9v-6f22-120770, http://dx.com/p/k-type-digital-industrial-thermometer-with-sensor-50-c-1300-c-7286) and i basically paid only 15$ but i'm fairly happy with this instrument for a few reasons,
1) I can quite trust it
2) The temperature probes supplied feels 1000x better than the ones you get with a 20-30$ DMM with temp
3) degrees C/F as well as kelvins measurement : handheld DMMs doesn't have that right? I don't like to do maths all the time
4) Max/Min/Avg, again, a average 50$ handheld DMM usually doesn't have Average!
5) Handy T1 minus T2 feature, i wasn't expecting that. I was expecting something like T1 and T2 on the same display
6) Office table test! It isn't as slippery as a used car salesman, in fact it doesn't even move at all but it doesn't have to
7) Twist test! It's good in this area
.1 degrees resolution all the way
Here's a few hate though :
Startup takes forever (5 secs i know is not slow but it's slow for a handheld device)
Plastic feels incredibly cheap
Flip up stand doesn't fall over but it feels like crap
The thing is, it is indeed terrible quality but i'll get to the main point okay?
IT'S A temperature meter. I don't really care for input protection on this meter because really which i wouldn't rent any of my meters to any idiots. Not even a agilent if i had one
I don't really have much else to say but i found flux residues all over the the input terminals and some white flux residue the jumpers, water soluble flux i guess?
Odd i know but the flux residue on the terminals are really RMA.
The back of the board is so boring ... it's only single sided
What's the result of a incredible cheapy? Don't buy it. If you bought it then sorry about that.
After a month or so of usage i went to my good friend's cal lab and discovered i have been led-on again!
To confirm my results that his lab really isn't at 28C i stuffed the probe into his 10C thermal chamber to find that it was indeed reading 5C higher, on T1
On T2 it was even worse, wafting to 10C above actual temp (And i ain't even using proper K probes he had, it just gives jibberish results on the DM6802-II, so i resorted to just using standard supplied TP01 probes)
As a result? Cheapies thermometer = crap. Buy a UNI-T for heaven's sake
Build quality is crap on this one and you can't trust it either because it's badly out of spec
