Thanks to a stupid short in rpm lcd panel ( i was tweaking with power on!!!) I've fried my brand new mini lathe control board and i need a replacement..
It is a Chinese MX 210V with a 750w 180v dc pwm motor. .
The problem is that original board replacement is hardly avaiable , is a "chopper type " with full rectifier and igbt. .(very poor filtering and horrible whining at 2500hz)
I tried to repair a blown smd regulator but once all voltage were ok nothing happens. .still no switching..
All the business is controlled by a mcu! So no spare parts existing..
I think there coud be better options in the market to drive this motor ( i'd like to keep it..) .
I need a suggestion on some models with better torque at mid low rpms and less whining noise )
What can i do?
Thanks
