If anyone minds reviving this old topic I'll go away and start a fresh one but the title does seem perfect…
I bought and built an Anet A8 Plus and it doesn’t work so I’d like to hear from anyone who’s either had the same or a very similar experience, or knows of useful tests that might be applied specifically to an Anet A8 Plus. (Please, no-one take the time to recommend different printers. I bought the Anet A8 Plus solely because if seemed to be the cheapest experimental entry to the 3D field.)
To the careless eye my printer seems to be working, inasmuch as the head makes apparently useful movements in all three dimensions, but nothing else happens; nothing comes out of the nozzle and nothing seems to be drawn into the head.
In the building process, every glitch but one was explained by the maker’s carelessness, whether in technicality or translation. (Am I alone there, or have others found the same?)
The one remaining unexplained problem concerned what seems to be the main heater element - not apparently included in the building instructions or the Parts Lists, though it might be included in the later ’Wiring sheet’ as either ‘Extruder thermistor-A… ’ or `Extruder heating-A…’ and its own stickers proclaim it to be ‘Extruder thermistorE_T-A’ and `Extruder Heat END-A’. I guess it’s safe to call that the main heater element can anyone say whether the exclusions and multiple names might matter?
Since I saw no single word about it in Anet’s instructions, I plugged that otherwise apparently spare item into the one electrical socket it seemed to fit and connected it to the two spare power terminals which had no other apparent purpose.
On powering up, the item soon glowed red hot; perhaps as it was lying loose, rather than being fitted into anything. No part of the instructions; merely the apparent undesirability of the red-hot glow caused me to look further, turning up another, mechanical socket under the extruder head, again apparently unmentioned, into which the heater element fitted perfectly.
Nothing apparently changed: after as before, the mechanism moved in all three dimensions but nothing else happened; nothing came out of the nozzle; nothing seemed to be drawn into the head. In whatever combination, the heater element and the connected sensors continued to report what looked like reasonable initial, rising and final temperatures.
It seems logical that one way forward would be to buy another heating element but before I do that please, has anyone else encountered exactly this situation and found any other solution, as for instance through tweaking either hard- or software?
