Replacing a used soldering tip (removal)1. Place the soldering tool into the safety rest. 2. Switch off the supply unit. 3. Wait three minutes until the soldering tip has cooled off. 4. Hold the soldering iron by the handpiece and pull the soldering tip off of the tool by the tip handle (3).Inserting a new soldering tip 5. Hold the soldering iron by the handpiece (4) and insert the tip into the soldering tool by the tip handle (3). 6. Switch on the supply unit and set the required temperature. Note: If different types of soldering tip are used, it is recommended that the tips be placed into the metal sockets provided on the back of the WDH 50 rest.
